dreaded heater core - Nissan Xterra Forum
post #1 of 20 Old 12-11-2011, 09:54 AM Thread Starter
bussbar
bussbar is on a distinguished road
dreaded heater core
I purchased an aftermarket core (spectra) minus the the plastic inlets(probably the cause of the leak) . I looked at nissan oem core, these parts come with the assembly. Is there a place where I can buy just the inlets and orings? Also, I read that there is a method of replacment without removal of the dash. Is this true?
bussbar is offline
post #2 of 20 Old 12-11-2011, 12:13 PM
RacerXXL
Quoted: 85 Post(s)
2000 XE Xterra
Garage
The outlets are not available from Nissan if they were many here would be ecstatic as they would not have to rip apart the dash to get the core out.....which is the only way I'm aware of to replace the core.
RacerXXL is offline
2000 XE Xterra
post #3 of 20 Old 12-13-2011, 04:01 PM
assassin_works
assassin_works's Avatar
2003 Xterra
assassin_works is on a distinguished road
wait so your saying that nissan dont produce the inlet and return manifold for the heater core anymore ?
assassin_works is offline
2003 Xterra
post #4 of 20 Old 12-13-2011, 05:56 PM
RacerXXL
Quoted: 85 Post(s)
2000 XE Xterra
Garage
If they did at one point....they no longer do according to the parts diagrams.
RacerXXL is offline
2000 XE Xterra
post #5 of 20 Old 12-13-2011, 10:53 PM
assassin_works
2003 Xterra
so what are we supose to do for us that have the heater manifolds broken any aftermarket co. building then or is it your just SOL
2003 Xterra
post #6 of 20 Old 12-13-2011, 10:55 PM
RacerXXL
Quoted: 85 Post(s)
2000 XE Xterra
Garage
None that I am aware of.
RacerXXL is offline
2000 XE Xterra
post #7 of 20 Old 12-14-2011, 02:14 PM
TJTJ
TJTJ's Avatar
Quoted: 192 Post(s)
Talking
The heater core itself has two long plastic tubes coming out of it...so, the tubes and the core are all one piece.
Those are the tubes that pass through the fire wall, and are the nipples you connect the heater hoses to in the engine bay.
There is no "manifold" per se...and the core cost me ~ $35 or so from Courtesy Nissan IIRC.
The swap itself takes 5 minute, super easy.
The process of getting AT the mofo, which is flat against the firewall behind the dash, etc...takes hours.
Putting it all BACK takes a few hours too.
I imagine that a pro dash guy could do it in less than an hour, but I was methodical, and taped labels on all the wires and screws, etc...so I'd remember where things went later, as I didn't do it all on the same day.
If LUCKY, the only broken parts are at the ENDS of the tubes IN the engine bay itself, where you can reach them...and, fit a hose section OVER them to essentially patch the leak point.
If the break/leak is on or too close to the passenger side of the firewall, you're screwed and glued.
-TJ
TJTJ is offline
post #8 of 20 Old 12-14-2011, 03:27 PM
assassin_works
2003 Xterra
oh i know how to do the job itself but everyone that i checked only sell the core but not the manifold tubes ( plastic tube) that connect core to heater hoses .... mine broke flush with the fire wall lol the only thing that i can think of is to tig some aluminum tubing in place of that plastic manifold
2003 Xterra
post #9 of 20 Old 12-14-2011, 03:40 PM
bac0nfat
bac0nfat's Avatar
Quoted: 6 Post(s)
bac0nfat is on a distinguished road
Mine broke pretty much flush with the firewall also:
I was able to fix it by removing the rubber grommet and pushing the hose through the firewall hole. There was enough room to get a clamp on it and make a secure connection. I don't have any photos of the fix, but can snap one if you want.
By the way, were you doing a body lift when this happened? Just curious, that's how mine happened.
Build Thread
2001 SE, AC Articulator kit w/ Bilstein shocks and Calmini AAL, 2" BL, Goodyear Wrangler Duratrac 33x12.5r15's, Cragar soft 8's 15x8 4.75" BS, bedlined plastics and bumpers
bac0nfat is offline
post #10 of 20 Old 12-14-2011, 04:16 PM
assassin_works
2003 Xterra
no it just started to leak from the hose when i went to replace the heater hoses they just came apart
2003 Xterra
