losing coolant - Nissan Xterra Forum
post #1 of 15 Old 11-14-2011, 04:56 AM Thread Starter
xfan11
xfan11 is on a distinguished road
losing coolant
my xterra is losing coolant and i think its either from head gasket or bolts that hold down lower intake.
ive done a lot of work on the x its a 3.3 but i cant seem to stop the coolant from leaking, I can smell it under the hood but it doesnt drip or anything.
when i replaced the lower intake gasket I noticed the bolts were crusty from old coolant, I wouldnt think they wouldnt hold coolant since the bolt itself has no sealer on the thread or anything. going off the idea this isnt right would it be head gasket or lower intake not seated properly ?
also on the passanger head all along where the head meets the the block theres old crust in a perfect line almost looks like the gaskets bigger then the heads and block. its on passanger but not driver head.
i was going to replace the passanger head gasket im just not sure if the coolant on the bolts is a bad lower intake gasket, head gasket or if the head may be bad causing fluid to leak in bolts.
xfan11 is offline
post #2 of 15 Old 11-14-2011, 08:08 AM
thanks28
thanks28's Avatar
Quoted: 1 Post(s)
thanks28 is on a distinguished road
I know this isn't a lot of help but if it were a head gasket leak then you would be able to tell by using a Block Tester (which you can get loaned to you by autozone) if your headgasket is leaking then there would be exhaust gases in the coolant system which will change the test flood color to indicate if so.
As for the intake gasket I am not really sure how to check those? But before you start replacing gaskets make sure all of your coolant system hoses and such aren't leaking anywhere because the coolant can get blown anywhere by the fan. Just feel along the bottom of all the hoses and such and see if there is any coolant on the bottom of anything like it has seeped out or something. Sorry if that isn't much help.
"Only the Best"
2002 Xterra SE 4x4 Solar Yellow
  • Cherry Bomb Glasspack Muffler
  • Concept Customs Lightbar w/ Pro Comp Long Ranges
  • Tinted All Windows to Match
  • Full Kenwood audio from Deck to Subs
  • Front Off Road Lights
  • PML
  • Custom Built Rock Sliders w/ Bedliner
  • Roof Basket w/ Spare Tire
  • DIY Hi-Lift Mount
  • 18" Rockstar XD wheels with 33"x12.50 Toyo Open Country Tires
Big Bird Build
thanks28 is offline
post #3 of 15 Old 11-14-2011, 08:52 AM Thread Starter
xfan11
I appreciate the info I guess you meant I can get the tester from autozone not Cant. I will try this tonite. Im thinking if the coolant is coming out of side of gasket and down side of block this test may not show though.
I remember reading a post sometime ago about these bolts having coolant on them but I cant find it and dont remember the outcome or reason.
any help/thoughts and experience are greatly appreciated
xfan11 is offline
post #4 of 15 Old 11-14-2011, 09:09 AM
phrog man
Chrome can go to hell
phrog man's Avatar
Quoted: 1 Post(s)
phrog man will become famous soon enough
famous leak areas are the throttle body and the small L shaped hose that goes on the thermostat.
2004 BLACK X-AUTO
Build Thread
phrog man is offline
post #5 of 15 Old 11-14-2011, 09:14 AM
porsche4786
porsche4786's Avatar
porsche4786 is on a distinguished road
Does yours look like a leak similar to the one I have at the following link?
http://www.clubxterra.org/forums/showthread.php?t=33689
You can rent a block leak test at autozone, but it isn't a for sure thing. (also, when I rented one, they didn't have or sell the liquid you need for it, I had to go buy a bottle at napa). It will only tell you if you have a coolant leak that is getting into your combustion chamber, not if it's leaking out, onto the side of the engine. You can get a die you put into your coolant, and then you use a black light to see where its coming out. But if you can already see it on the side of the engine, you should be able to see where it's coming from. First thing I'd check are the two hoses on the back of the upper plenum, and the heater hoses. If your lucky, it's one of those, and not your head gasket. Another thing that I think helps, (I've never done it, but have one), you can use a leak down tester, to check for cylinder leaks. How much coolant are you going thru? Does your radiator stay full for a long time?
2004, XE, 5 speed manual
My Build Progress...
porsche4786 is offline
post #6 of 15 Old 11-14-2011, 09:34 AM
XBetty
XBetty's Avatar
XBetty is on a distinguished road
I've been having a similar problem. Since I bought it you could smell the coolant after a long drive and this summer it actually started over heating. Its leaked coolant twice and when it did it was ALOT. This has only happened after not letting it warm up properly.
As far it looks, I think its the the lower intake plenum gasket on the passenger side. Not sure if that helps you but there you go.
Mine's getting replaced this weekend, so hopefully it works out.
3" bodly lift, 32" BFG KM2 on Eagle Alloy wheels, custom cold air intake and remote start.
Xmas List:
Custom front bumper
XBetty is offline
post #7 of 15 Old 11-14-2011, 09:35 AM Thread Starter
xfan11
the L / ? shaped hose to throttle body I did i swore that was the problem because it was wet but i cleaned the surfaces of the pipes it goes on and replaced now its dry but i still get the smell.
the 2 hoses on back of intake are also new ive replaced basically all hoses radiator and water pump.
@porsche did you resolve your leak in that picture ? problem is I dont see coolant anywhere I just smell it.
when i had the intake manifold off i saw old crust like coolant all along the gasket area where head meets block all along the whole length of the block but didnt look to be running down and nothing was wet but truck sat all nite too.
Im going to get the analyzer and also some die this way when i rip it apart I can put the light on it and see.
the bolts for the intake having crusty coolant on the is still puzzling me because i know the bolts themselves couldnt hold water so im nmot sure if somethings broke/cracked in the head or it just leaked down the bolt holes from somewhere else.
I guess if nothing more when i pull it back apart this weekend il have to take some pics of what imtalking about because i know it sounds confusing.
@xbetty thats about where i think mines leaking its hard to tell for sure though if its the manifold or head goodluck with yours definately post up on whats found im doing the work myself so not so bad but if your paying maybe throw some die in so once they get it all apart they cant put a light on to see its that intake gasket for sure.
xfan11 is offline
post #8 of 15 Old 11-14-2011, 09:39 AM
porsche4786
Let us know what happens, and if you find anything else.
edit, re-read your post, it's running on the passenger side....
post #9 of 15 Old 11-14-2011, 09:45 AM
XBetty
XBetty's Avatar
My boyfriend is actually fixing it at his shop, so he does have all the fancy tools. I'll make sure to see what he finds and let you know.
Xmas List:
Custom front bumper
XBetty is offline
post #10 of 15 Old 11-14-2011, 09:45 AM
phrog man
phrog man's Avatar
Quoted: 1 Post(s)
[QUOTE=xfan11;462482]the L / ? shaped hose to throttle body I did i swore that was the problem because it was wet but i cleaned the surfaces of the pipes it goes on and replaced now its dry but i still get the smell.
im sorry i just dont understand what this means sir.
2004 BLACK X-AUTO
Build Thread
