P0328/P0325 code. Knock sensor information. - Nissan Xterra Forum
post #1 of 173 Old 10-21-2011, 04:44 PM Thread Starter
Xterra Mike
Silver Submarine
Xterra Mike's Avatar
Quoted: 14 Post(s)
2001 SE Xterra
Xterra Mike is a jewel in the rough Xterra Mike is a jewel in the rough Xterra Mike is a jewel in the rough Xterra Mike is a jewel in the rough
Garage
I'm gonna make this a sticky cause its just talked about so much and recently there has been new information on this topic. If you are getting a PO328/P0325 code on your truck it is the knock sensor and it probably has gone bad but there are other possible reasons for getting the code. You might have gotten a bad tank of gas or your ignition system isn't working as good as it should. I would recommend you fill your tank with hi octane gas or gas treatment, run through that tank and check for the KS code again after you have cleared it and do other repairs before attempting the knock sensor replacement or by pass. Make sure your ignition system is working as it should. If after you have do all that and you are still getting the KS code your KS or harness might be bad. Its your choice to to do the replacement or by pass. We are trying to give you all the information we can to help you in your decision. There is not one good answer for your decision. Some decide to do the replacement. Some decide to do the by pass and some decide to leave it alone. Again the choice is yours!
It seems as though when your knock sensor goes bad the ECM will retard the timing to a preset position in order to prevent your motor from "knocking or pinging". This retard in timing will possibly reduce power and you will get slightly less MPG's but probably not enough to notice in the NA 3.3. In the supercharged 3.3 the ECM will put the truck in "limp" mode and you will notice a major reduction in power. This is to prevent your 3.3 from destroying itself. By doing the knock sensor by-pass you have now removed the safety from the system and will have to be diligent in what type of fuel you run and your driving habits. The knock sensor is attached to the cylinder block. It senses engine knocking using a piezoelectric element. A knocking vibration from the cylinder block is sensed as vibrational pressure. This pressure is converted into a voltage signal and sent to the ECM. Freeze frame data will not be stored in the ECM for the knock sensor. The MIL will not light for knock sensor malfunction. The knock sensor has one trip detection logic.
#1. Bad knock sensor won't set an SES light. The code was already there when the light came on.
#2. Bad knock sensor will possibly decrease fuel economy.
#3. Bad knock sensor will Possibly retard timing causing a slight reduction in performance but probably not enough to notice without monitoring live data.
#4. Knock sensor bypass should be done at your own risk especially with a SC Xterra.
The red arrow points to the location of the knock sensor:
Xterra Mike is offline
2001 SE Xterra
post #2 of 173 Old 10-21-2011, 05:07 PM
miskywhisky
Quoted: 29 Post(s)
Couple things to add:
1. Do not do anything if you get the code once, it could be a bad tank of gas, impurities whatever. Fill up again and half way through take it to a autoparts place and have them pull the codes again (most will for free). If it remains, do it again at another tank. Give it a few tanks before considering anything.
2. Once you are certain that its bad you have a few options:
Get it repaired
Pros: It put your engine back in to correct working order
Cons: EXPENSIVE repair, quotes have been in the $750-$1500 range
Leave it
Pros: You don't have to do anything
Cons: Your engine may not perform at its peak and you may be costing yourself some gas milage (how much varies)
Relocation mod
Pros: Moves it to a much more easily accessible spot, cost is much cheaper then replacement ($200 using OEM parts), your engine has knock protection again
Cons: Not in the factory location, not as accurate.
Bypass mod (not recommended for SC engines)
Pros: Regains timing and milage lost from bad sensor, very cheap
Cons: You now no longer have ANY knock prevention, could lead to engine damage but unlikely.
miskywhisky is offline
post #3 of 173 Old 10-21-2011, 05:35 PM
BrushWorks
BrushWorks's Avatar
BrushWorks is on a distinguished road
Thanks for the pro/con report. I almost feel like I SHOULD do it the right way. My luck, "cheating the system" will wind up with a major fk up later on. lol
Uploaded with ImageShack.us
'02 XE/V6 Xterra Silver Ice
General Grabber HTS 265/70R16 (daily drivers)
Rage Safari Roof Rack with cargo net
Pioneer CD/DVD/GPS (in dash touch screen)
Cobra 75 WX ST CB Radio / 4' Firestik Antenna
BrushWorks is offline
post #4 of 173 Old 10-21-2011, 05:53 PM
RacerXXL
Quoted: 85 Post(s)
2000 XE Xterra
Garage
If your NA truck is throwing a KS code you're not cheating the system as it is already retarding the timing to prevent knock.
RacerXXL is offline
2000 XE Xterra
post #5 of 173 Old 10-21-2011, 05:55 PM
BrushWorks
BrushWorks's Avatar
Sorry, by -cheating the system- I meant would be to Reposition the KS and not Replace it where it belongs under the manifold.
post #6 of 173 Old 10-21-2011, 06:01 PM
drbandkgb
It was always fumbles
drbandkgb's Avatar
Quoted: 1 Post(s)
drbandkgb is a splendid one to behold drbandkgb is a splendid one to behold drbandkgb is a splendid one to behold drbandkgb is a splendid one to behold drbandkgb is a splendid one to behold drbandkgb is a splendid one to behold drbandkgb is a splendid one to behold
For noobs don't not freak out..
We seem to get some new people on here that read a few lines of a topic then become that guy that has all the answers.. Make up your mind on this topic.. Please read up on this topic as much as you can and go from there
drbandkgb is offline
post #7 of 173 Old 10-29-2011, 06:27 PM
TriciaH_88
TriciaH_88 is on a distinguished road
Question: Recently my car when it is idle shakes/vibrates it is subtle and almost seems like it is running out of gas (but it has a full tank) I've been putting STP stuff in my xterra but it doesn't seem to make a diff. Friday I got the CEL and the two codes that came up are 450 and 325. I tried to find the knock sensor but I can't find it in my car. I freak out when something is wrong with my car and I don't like the vibration thing it is doing. Help =/
TriciaH_88 is offline
post #8 of 173 Old 10-29-2011, 06:51 PM
BrushWorks
BrushWorks's Avatar
The knock sensor is locate under the plenum on the top of the engine. From what I've read, it's anywhere from 6-10hr job.
post #9 of 173 Old 11-15-2011, 05:06 PM
mattyg
mattyg's Avatar
mattyg is on a distinguished road
curious as to why you say NOT RECOMMENDED FOR S/C ENGINES? the person who has the DIY write-up on this site is doing it to a S/C engine and sounds like it worked just fine. i'm not saying your wrong - you may be spot on, which is why i'm asking. i have a S/C and am considering doing this mod. i paid to have the dealership replace the original and it made a HUGE difference, for sure, but i still think it's robbing the S/C at times even still, so it would be nice to just make that thing go away. and i ALWAYS use premium fuel (at least 93 octane).
2002 SE Supercharged, 4x4, 5-speed manual, leather, sunroof, intake modification w/ K&N drop-in, Bilstein HD's
mattyg is offline
post #10 of 173 Old 11-15-2011, 08:42 PM
kriskool123
Seasoned
kriskool123's Avatar
03 Xterra
kriskool123 is on a distinguished road
x2 mattyg.. i have the 03 SC an always use premium... id like more info on the mod because i really dont wanna drop major coin on something thats gonna pop up in the next 50k miles anyways an is a bitch to get to
looking for:
1.USED front and back diff gears 4.88 or 5.13
2.USED ARB front and rear locker
kriskool123 is offline
03 Xterra
