The 2 screws that hold the latch to the glass itself are either loose or you are missing one and the other one is loose.
Pull the cover off the latch side that is mounted to the roof itself. Then fold the latch forwards, revealing the screws that hold the latch to the glass. Tighten those up.
If those are tight, then adjust the latch backwards, which will tighten it up. You might even find that the attatchment screws for the latch to the roof are loose. Then you need to tighten those and adjust it so that the latch has good pressure when latching the sunroof.
Just make sure they're all tight, everythings adjusted and your noise will go away.
I cannot wait to get to my car and check out the assembly. Never even thought to pull the cover since it was so easy to just slightly pull down on the flip handle to increase tension.
Thanks! Will let you know what I find. I happen to have a regular and phillips screwdrivier in my car.
- Dan
Black 2000 SE (lovngly maintained)
Ok - fixed - but as predicted, I am missing a bolt.
Anyone know where to get a replacement other than the dealer?
- Dan
Dan, pull the existing bolt and go to your local ACE hardware store or any store which will sell an individual bolt. Home Depot usually sells 4 to a pack.
Just match the bolt up when you go in
Originally Posted by Steeze
That's what the dealer told me. I'm reluctant to pull it so as to lose the ability to put them back in easily, but may just do that. May also be lazy and order it, have it delivered to office, and put it in on the way home...
If I have time, I may just head over to the mom and pop Ace that has drawers and drawers of metric bolts....
Muchas gracias for the help.
- Dan
