Tail light fuse keeps blowing - Nissan Xterra Forum
post #1 of 9 Old 10-07-2011, 08:48 AM Thread Starter
Thecubscout
Thecubscout is on a distinguished road
My tail lights and dash lights keep blowing fuses, prior to that problem my ac was leaking water into the footwell area passenger side.
I wondered if the water had some how engulfed the wiring loom under the carpet, so I stripped it all back and sure enough it was all soaking with water.
I dried out everything and put it all back, but the fuses are stil blowing.
Any ideas as to what it may be that is making the fuses blow?
Thecubscout is offline
post #2 of 9 Old 10-07-2011, 09:28 AM
19kdrill
19kdrill's Avatar
19kdrill will become famous soon enough
Mine was blowing when hooked my small utility trailer to the plug on my hitch. Turns out my trailer wiring was jacked, so every time I plugged up the little 4-wire harness, it would blow my fuse, so maybe check to see if your hitch wiring is in good shape.
GL!
rob.g
Rob.g
CX Firefighters
I just want to wish you good luck . . . We're all counting on you
19kdrill is offline
post #3 of 9 Old 10-07-2011, 01:54 PM
Coxterra
Coxterra's Avatar
Quoted: 5 Post(s)
Coxterra is on a distinguished road
That happened to me once. Mine was the front bumper marker lights. One of them had a small cut in the wiring and it was shorting out because of that. It happened right after I was driving through snow so you may have a similar issue as I did with the moisture aspect.
If you can find any exposed wiring there, you might find your problem.
Cameron
02 SE/SC 5spd/ 2" AC BL /3" AC SL /Calmini HD Steering/ 33" Duratracs on Cragar Soft 8s / Volant CAI / Rancho 9000XLs/ Concept Customs rear tire carrier bumper/Shrockworks front bumper
Build Thread
Coxterra is offline
post #4 of 9 Old 10-07-2011, 02:09 PM
RacerXXL
Quoted: 85 Post(s)
2000 XE Xterra
Garage
Isn't there an issue with the wiring where it enters/leaves the rear hatch/body sometimes becoming exposed and shorting to ground on the rear hatch/body sheet metal?
RacerXXL is offline
2000 XE Xterra
post #5 of 9 Old 10-07-2011, 04:42 PM
xtacular
Spaz
xtacular's Avatar
Quoted: 74 Post(s)
Bingo, this is what came to my mind. It can crunch through all kinds of wires.
Also, did you clean out the AC drain?
2002 Super Black 5 Speed 4x4
xtacular is offline
post #6 of 9 Old 10-13-2011, 10:16 AM Thread Starter
Thecubscout
I couldn't guite see how clean out the ac drain, but I did pull up the carpet and interior and dried everything out as it was all lying in water, but after it was all dry I tried another fuse and it stayed on for quite a while, that is until I got in to drive it and then it blew again. Whatever it is it is somewhere where it is moving.
Does anyone know how to clear out the ac drain?
post #7 of 9 Old 12-14-2011, 09:25 AM
hiho
hiho is on a distinguished road
My 2002 Xterra blows the fuse randomly and usually after my wife has had it parked at the airport for a few days.
I suppose water is getting in somewhere. I need a warm sunny day, a few hours, some silicone and electricial tape. Too bad it's winter here.
Until Spring rolls around I'll keep a supply of spare fuses.
hiho is offline
post #8 of 9 Old 12-14-2011, 08:20 PM
Spruce
2007 Xterra
Spruce is on a distinguished road
I do not know about the first gens first hand, but on my 07 I kept noticing my carpet was wet all the time. Mostly during the summer months when the ac was running. I finally got around to working on finding the leak, I thought there was a good possibly that it could be getting in from where I passed the 2ga wire through the wire boot on the passenger side. but what I found was the ac drain was clogged with a muddobber nest. I also pulled the fan motor out and pulled out a bunch of acorn pieces, I am guessing from mice.
Spruce is offline
2007 Xterra
post #9 of 9 Old 12-17-2011, 12:39 PM
Gustling
Guenstling
Gustling's Avatar
Gustling is on a distinguished road
same problem...
But how do I remove the front side marker? That bulb is out, but I can't figure out how to get to the bulb to get it out. I bought a manual, but it doesn't help...
Gustling is offline
