timing belt replacement - Nissan Xterra Forum
post #1 of 34 Old 08-13-2011, 01:56 PM Thread Starter
johnd
johnd is on a distinguished road
Hello all,
I just joined the site as it seems like you have a lot a good contributors. Great job here! I have looked around and in the DIY section as well, but hoping I can get a bit of guidance.
I have a 2000 v6 Xterra and a couple days ago it appears the water pump went out. Antifreeze everywhere and the car overheated like a champ! Given where the water pump is by the time I get to it to check I might as well replace half the parts on the front end!! lol
I have everything taken out to the main pulley on the bottom, 27 mm and want to make sure I get the rest right.
Here are my question if anyone can help out (thanks!):
1- I had to disconnect the trans cooler hoses from the rad. do I have to do anything special when putting this back?
2- The timing belt looks in good shape, but it appears that to replace the water pump I have to remove the lower pulley and upper pulley to get the bracket off to get to it? Is this correct?
3- If I am right about #2 then my biggest concern is making sure I get the pulley's and timing belt back on in the right way. Can someone give me the tips and tricks to doing this? The manual goes into a bunch of TDC alignment crap, but it would seem you could mark all this stuff ahead of time to avoid that.
4- Also if I have to take all this stuff off I plan to buy the timing belt kit, but am a little unsure about some of the pieces in it. like the spring and seals(crankshafts? I assume it will make more since once I pull the top pulleys off?)
Thanks guys!! I love my X !! it has 165000 miles on it and has never given my hardly any trouble, I doubt I will ever be able to part with it!!
johnd is offline
post #2 of 34 Old 08-13-2011, 04:03 PM
slownis
slownis is on a distinguished road
You do need to do the entire thing, including timing belt, camshaft and crankshaft seals, and the water bypass hose. These are all very important to do at once, or inevitably you'll be tearing it down again later. I changed both cam seals during my last timing belt job, but neglected to do the crank seal. Guess whats leaking now?
There is more than one timing belt thread in the how-to section. You want to find them and follow them. Take it step by step and you'll do fine.
slownis is offline
post #3 of 34 Old 08-13-2011, 05:18 PM Thread Starter
johnd
Thanks for the replay. I have looked but do not see my specific concerns. I do plan to replace as much as I can but before I remove the pulleys I want to feel comfortable about how to get it back together.
johnd is offline
post #4 of 34 Old 08-13-2011, 05:18 PM
phrog man
Chrome can go to hell
phrog man's Avatar
Quoted: 1 Post(s)
phrog man will become famous soon enough
here is the link to the thread you need.
q#1- no just re-insert them and check fluid lvl when done
#2- the belt along with the other components in the thread i provided MUST be replaced
#3- again the thread gives good info, and this
#4- yes it will all come together with all the reading i gave you and once you tear into it.
2004 BLACK X-AUTO
Build Thread
phrog man is offline
post #5 of 34 Old 08-15-2011, 06:01 PM Thread Starter
johnd
Thanks for the help!! Can anyone tell me where you normally hook up the puller to the crank pulley? I am a bit concerned about damaging the pulley.
The above listed thread shows this puller being used:
Large Size 3 jaw puller for crankshaft pulley - I used Autozone P/N 27078
Thanks!
John
johnd is offline
post #6 of 34 Old 08-15-2011, 06:32 PM
rjr162
rjr162's Avatar
Quoted: 1 Post(s)
rjr162 will become famous soon enough rjr162 will become famous soon enough
Do *not* use a 3 jaw puller. Use a harmonic balancer puller of some sort (the one that is a straight bar with two slots on either side for bolts to go in or the "bird foot" looking one also with holes for bolts). The crank pulley has two threaded holes the bolts will thread into. They are 6mm bolt holes iirc, but my puller set didn't have any that small so I rethreaded them to a 1/4" iirc so I could use the bolts I had
rjr162 is offline
post #7 of 34 Old 08-15-2011, 10:23 PM
yellowbug
yellowbug's Avatar
01 Xterra
yellowbug will become famous soon enough yellowbug will become famous soon enough
I used a three jaw puller. The exact one from auto zone you listed. Once you get the bolt loose take it out and take the washer off, then put the bolt back in snug not tight this is what the puller will push off of. Position the claws or jaws of the puller around the first part of the puller. Use a socket to turn the puller bolt as the puller tightens it will pull the pulley right off of the crank shaft. If you have any questions pm me your number and I'll call you.
yellowbug is offline
01 Xterra
post #8 of 34 Old 08-15-2011, 11:00 PM
rjr162
rjr162's Avatar
Quoted: 1 Post(s)
Ill repeat.. its not a wise idea
Take a poll of clubxterra folks who have broken the crank pulley using a 3 jaw puller vs those who have broken it using a harmonic balancer type puller
rjr162 is offline
post #9 of 34 Old 08-15-2011, 11:05 PM
yellowbug
yellowbug's Avatar
01 Xterra
In my pulley I didn't have any where to thread in a harmonic balancer puller. I tried it first. With the puller from auto zone it slid right off. No binding. Nothing. I pulled my pulley off three times with that puller.
01 Xterra
post #10 of 34 Old 08-15-2011, 11:07 PM
rjr162
rjr162's Avatar
Quoted: 1 Post(s)
The OEM pulley has the holes, but they can be a bitch to find being so small and dirt can cover them up
rjr162 is offline
