Vacuum Cut Valve Bypass Valve - Nissan Xterra Forum
post #1 of 7 Old 08-02-2011, 08:19 AM Thread Starter
outwiththeold
outwiththeold's Avatar
Quoted: 6 Post(s)
2000 XE Xterra
Any one have to replace there Vacuum Cut Valve Bypass Valve? I have a P1491 code on my 2000 xterra.
warn manual hubs,PML, and a ditched rear sway bar.K&N Drop w/ resonators removed.Plastics Repainted Black.
outwiththeold is offline
2000 XE Xterra
post #2 of 7 Old 08-03-2011, 01:28 PM
seanpage86
Location: Home town Tampa, FL Currently stantioned in Minot, ND
2004 SE Xterra
seanpage86 is on a distinguished road
same thing.... does it even need to be replaced?
seanpage86 is offline
2004 SE Xterra
post #3 of 7 Old 08-03-2011, 06:50 PM Thread Starter
outwiththeold
Quoted: 6 Post(s)
2000 XE Xterra
I was going to check it out, but it fell apart in my hands. So I have a new one on order.
1433-54u0a $96.53,stealer ship wanted over $150.00.My new bendpak lift makes this kind of repair much easier..
2000 XE Xterra
post #4 of 7 Old 08-30-2011, 07:19 AM Thread Starter
outwiththeold
Quoted: 6 Post(s)
2000 XE Xterra
After this valve was replaced,the x runs like a champ.
2000 XE Xterra
post #5 of 7 Old 05-11-2013, 09:46 AM
tbonez18
2003 Xterra
tbonez18 is on a distinguished road
outwiththeold,
I have the same code where is the Vacuum Cut Valve Bypass Valve located? Is it above the left front wheel well or located in the rear near the gas tank? I want to replace my Vacuum Cut Valve Bypass Valve also I just don't know where it is located or where to get the part from? Any help would be greatly appreciated.
thank you,
tbonez18 is offline
2003 Xterra
post #6 of 7 Old 05-13-2013, 02:34 PM Thread Starter
outwiththeold
Quoted: 6 Post(s)
2000 XE Xterra
You can see through the rear passenger wheel well. It has a green connector.
And what is your location???
2000 XE Xterra
post #7 of 7 Old 05-13-2013, 03:21 PM Thread Starter
outwiththeold
Quoted: 6 Post(s)
2000 XE Xterra
http://www.courtesyparts.com/xterra-...14_47_446.html
2000 XE Xterra
