Ok ladies and gents. I need to replace both of my valve cover gaskets. The rock auto box came in so it's go time. It seems like a straight forward but time consuming job. Anything I need need to know to keep the surprises to a minimum?
Yeah, it needs a new gasket too!
Also while you are under there, check that the waterline hoses are not brittle or leaking. (on the bottom of the plenum)
Nickolae, did you try tighting the screws on the valve cover? I thought mine were leaking too then I read somewhere that the scres that hold them on tend to come loose and cause leaking. I tightened mine down and no more leaking. I was suprised how loose the screws were when I tightened them up.
Tim... 2000 Xterra SE 4x4
Mods: K&N Air Filter, AC PML, 17" Pro Comp Wheels, 33" Wild Country MTX, Custom Rear Bumper w/Tire Carrier, 2 inch BL, Hella 500FF's, AC Prerunner bumper, Xoskel light bar with 4 KC Daylighters, AC's IAB, Rancho RS5000 Shocks. Official Build Thread
Thanks Tim for mentioning the obvious. They were seriously loose. Saved me a ton of work so I got a chance to replace the horn I ruined at NXM and change the oil.
The hardest part for me was the two short coolant hoses behind the intake plenum (near the firewall). Ended up cutting them off and replacing them. Should have started with that idea and would have saved an hour.
2002 Xterra XE 3.3 4x4 auto | JL 500/1v2 + 10W7 | Viper 5901 remote starter | Rear sway bar delete | Bilsteins all around | IAB | 2" DIY BL | KC HiLiTES on homemade roof bar | AC Shackles/PML | 33x12.5/15 Goodyear Wrangler MT/R with Kevlar on Cragar Soft 8s | Skid Row skids | Yakima Loadwarrior | Beginning of a build thread
Same here! exactly my story 13 of 14 absulate loose!
almost all mine on passenger side were loose i can tell my valve cover gaskets have been replaced (at least the passenger side) because one of the screws on it was a bolt so they must have lost one screw while doing it.(hopefully they did drivers side and intake gaskets) but they were all loose except that bolt lol. and the ones i could get to on drivers side were all a little loose but i think the intake plenum keeps those tight. i have a small oil leak from what appears to be where the oil pan sits near the rear main seal/bell housing area and my mechanic diagnosed it as a rm seal leak but seeing as those screws were loose and i see a small amount of oil around rear of passenger side valve cover im leaning towards those screws being loose. we will see! wish me the best on it
MY BRIGHT AZZ LIGHTS!
MY STEREO BEATS EM ALL!
My Laundry List
LIFT()
MUD TIRES()
DROP IN K&N FILTER(X)
UPGRADE STEREO(X)
RESTORE BUMPERS(X)
HID AND PIAA FOGS(X)
FIX UP HEADLINER()
WINCH()
MUFFLER UPGRADE()
