ABS light just came on - Nissan Xterra Forum
post #1 of 4 Old 06-15-2011, 07:16 AM Thread Starter
jimmygunz3
jimmygunz3's Avatar
jimmygunz3 is on a distinguished road
My abs light just came on, I have a 00 x. Is there a known problem with the abs system?
jimmygunz3 is offline
post #2 of 4 Old 06-15-2011, 08:39 AM
Itsme
Itsme's Avatar
Quoted: 1 Post(s)
2000 4x4 Xterra
Itsme will become famous soon enough Itsme will become famous soon enough
usually, I find the sensors on the wheels (front) get gunk on them and make it throw the code. Also they can get detached from off roading, or even break the wires. All must work or it will put on the ABS light.
There is also the possibility that one got mashed!
Also make sure the brake fluid is up. if it is low, could be due to low brake pads, or leak. Ckeck lines on right front, as they can wear thru.
Hope you find it and can easily correct the fault.
Itsme
2000 X SE
Itsme is offline
2000 4x4 Xterra
post #3 of 4 Old 06-15-2011, 12:21 PM
AaronsX
AaronsX's Avatar
AaronsX will become famous soon enough AaronsX will become famous soon enough
Yeah mine came on this weekend at Woolys. Probably from the combination of mud on the sensor and having to ride the brakes down the mountain side. I turned it off for about 30 minutes and it never has come back on.
My Build: Smokey The Bluegrass Bomber
Poor Mans Lift (PML) [x]
8,000lb Winch[x]
Kenwood Aftermarket Sound System[x]
Plastics Repainted Black [x]
Resanators, Rear Sway Bar, Nerf Bars Removed [x]
Rims Painted [x]
30" Firestone Destination A/T's [x]
Cobra CB & 3' Firestik Antenna [x]
Cherrybomb Glasspack [x]
AaronsX is offline
post #4 of 4 Old 06-15-2011, 12:41 PM
CMD
\m/>_<\m/
2003 Xterra
CMD will become famous soon enough CMD will become famous soon enough
A common problem with drum brakes as the mud can screw around with the brakes them selves and the sensor inside the drum.. Powerwash good into the drum and it should clean it self out.
- Sean
Totaled - 2003 XE - 3" SL, 2" BL, Sliders and Skids, 33" MT's
Build Thread - Warthog
http://www.clubxterra.org/forums/showthread.php?p=515519#post515519]"Second X"
Ohh, Second Gen? Typical....
CMD is offline
2003 Xterra
