Cigarette Lighter Not Working - Nissan Xterra Forum
post #1 of 5 Old 04-19-2011, 01:12 PM Thread Starter
butchf1
2008 Xterra
butchf1 is on a distinguished road
I recently tried installing a Garmin 765T GPS into my Xterra. I purchased the GPS Navigation housing from Nissan. I installed the unit and housing and I split into the power source from the cigarette lighter. After installing the splitter the cigarette lighter no longer works and I am not getting any power to my GPS. I checked the fuse in the glove box and it was good. Is there a second fuse or another fuse that is associated with the cigarette lighter? Is the second fuse in the Fuse and fusible link box or the Fuse and relay box. I am pretty sure since there is power generated to the cigarette lighter all the time there probably is no switch and draws power directly from the battery. Any help would be greatly appreciated.
Thanks again
butchf1 is offline
2008 Xterra
post #2 of 5 Old 04-19-2011, 01:29 PM
rjr162
rjr162's Avatar
Quoted: 1 Post(s)
rjr162 will become famous soon enough rjr162 will become famous soon enough
Check the fuse box under the hood. I'm not 100% sure which fuse it may be as I don't have a 2nd Gen.
rjr162 is offline
post #3 of 5 Old 04-19-2011, 06:54 PM
bowlerx
bowlerx's Avatar
bowlerx is on a distinguished road
should be dash lights/ brake lights/ cig lighter. all 3 should be in one fuse. atleast, they are in every other car i have ever owned.
'02 se/sc super black / oem window visors/ carbon fiber dash kit(real) / k&n drop in / tow pkg / PML / 31" Toyo Open Country's / frontier desert runner wheels / rancho RS5000's
bowlerx is offline
post #4 of 5 Old 04-19-2011, 07:04 PM
J Everett
J Everett's Avatar
2008 Xterra
J Everett is a jewel in the rough J Everett is a jewel in the rough J Everett is a jewel in the rough
The power for the GPS is supposed to be tapped into the switched power lead for the radio head unit.
The cigarette lighter is a separate circuit from dash/tail lights. The dash plug and the power plug in the cargo area are on one non-switched circuit that is fused under the hood. The power plug in the console is switched and is fused in the dashboard fuse block.
The correct fuse is circled in red:
--Jason
My 2008 Super Black SE "The Elephant"
The ass of my ride will swap ends faster than the OP will fail an English class.
J Everett is offline
2008 Xterra
post #5 of 5 Old 04-19-2011, 07:32 PM
Donore
Seasoned
2011 Xterra
Donore is on a distinguished road
A couple of things you can check:
Make sure the correct gauge of wire was used.
Check the wire connections to ensure polarity was respected, and connections are tight. If you didn't crimp, make sure that one of the wires didn't come out of the wire nut when you buttoned it back up.
Paved Roads: A perfect example of wasteful government spending.
Donore is offline
2011 Xterra
