Spark Plug Gap - Nissan Xterra Forum
post #1 of 8 Old 03-10-2011, 06:58 AM Thread Starter
tua59450
tua59450 is on a distinguished road
Spark Plug Gap
hey guys changing my Spark Plugs today was wondering what the spark plug gap is on a 2004 3.3 non supercharged
tua59450 is offline
post #2 of 8 Old 03-10-2011, 03:41 PM
Mogman
Mogman's Avatar
Quoted: 9 Post(s)
2011 Pro4X Xterra
Mogman Totally Rocks Mogman Totally Rocks Mogman Totally Rocks Mogman Totally Rocks
Garage
Your owners manual should tell you. There might also be a sticker on the inside of the hood.
I don't know much about the first gens, but my manual specifically states to NOT gap or clean the plugs. The platinum plugs are maintenance free. Replace after 100k or so.
Go confidently in the direction of your dreams! Live the life you've imagined. As you simplify your life, the laws of the universe will be simpler. - Thoreau
Mogman is offline
2011 Pro4X Xterra
post #3 of 8 Old 03-10-2011, 05:17 PM
leonarlay
leonarlay's Avatar
leonarlay is on a distinguished road
Originally Posted by tua59450 View Post
hey guys changing my spark plugs today was wondering what the spark plug gap is on a 2004 3.3 non supercharged
0.039-0.043
leonarlay is offline
post #4 of 8 Old 04-07-2011, 07:38 AM
PhilKratz
Seasoned
PhilKratz's Avatar
Location: N.E. Philadelphia Pa. Orig. from Lewes Delaware
2000 x Xterra
PhilKratz is on a distinguished road
I just changed mine with ngk v power plugs mine are at .042 and everything is good
Sent from my iPhone
PhilKratz is offline
2000 x Xterra
post #5 of 8 Old 04-09-2011, 08:17 AM
tj02x
Seasoned
tj02x's Avatar
tj02x is on a distinguished road
It does differ on the plugs you get... I just changed mine with ngk's and they called for .44 I got my plugs a napa and napa actually prints the gap right on the reciept for the plugs you get...
The last set I put in were champions... and don't quote me for sure but I think they got gaped at .55
And whether or not your manual says not to gap the plugs.. or the place you get the plugs from tells you that they are pre gaped.... make sure you still check them... I have ran into that problem with customers cars a lot...
tj02x is offline
post #6 of 8 Old 04-10-2011, 08:17 PM
JohnInNY
Quoted: 2 Post(s)
2005 Xterra
JohnInNY is on a distinguished road
.44 for the 2005, on the box of NGK's platinum laser, it say's do not gap. I checked each one, most were about .43, two were like .46 so I just pressed in gently. The factory ones I took out, same brand etc. @136K miles, were at .46 - .48 I guess from a little wear. 2 things: ALWAYS check your parts at the store, I have been getting a lot of returned, greasy stuff, so now I check before leaving the store, and as far as spark plugs, check the gap, Friday at a factory can bring some bad luck.
JohnInNY is offline
2005 Xterra
post #7 of 8 Old 04-20-2011, 03:28 AM
Mogman
Mogman's Avatar
Quoted: 9 Post(s)
2011 Pro4X Xterra
Garage
The automobile / engine manufacturer's gap spec is the one that should be followed, not the spark plug manufacturer (they have no idea what engine their plug goes in, and it could be hundreds of different engines with different specs).
As for gapping the plugs: gapping techniques can damage the plug. Be careful or be sorry. If you visit different plug manufacturer's websites and read their FAQ, you will see that they will tell you that it's a good idea to check it, but not always a good idea to adjust it.
For example...here's what Bosch has to say:
Do I need to gap my plugs?
Maybe, but likely not. Many plugs are pre-gapped for their most popular applications, however, the gap can be altered if the plug is dropped or mishandled in packing/shipping. Therefore even if the plugs are supposedly preset for your motor, it is always wise to check the gap on each plug prior to installing. For information on how to adjust the gap see Proper Gapping.
It is not recommended that you adjust the gap on multi-ground plugs.
Bosch Ir Fusion, +4, +2 Spark plugs are never to be gapped for any application. The gaps on these plugs are not adjustable.
Mogman is offline
2011 Pro4X Xterra
post #8 of 8 Old 04-20-2011, 10:19 AM
emmdock
emmdock is on a distinguished road
I think it's .039-.044 but it also says don't mess with them because you can chip/damage the coating on the electrode.
2002 Xterra XE 3.3 4x4 auto | JL 500/1v2 + 10W7 | Viper 5901 remote starter | Rear sway bar delete | Bilsteins all around | IAB | 2" DIY BL | KC HiLiTES on homemade roof bar | AC Shackles/PML | 33x12.5/15 Goodyear Wrangler MT/R with Kevlar on Cragar Soft 8s | Skid Row skids | Yakima Loadwarrior | Beginning of a build thread
emmdock is offline
