dash lights and back lights keep blowing fuses - Nissan Xterra Forum
post #1 of 15 Old 02-20-2011, 05:38 PM Thread Starter
crmarie
crmarie is on a distinguished road
does anyone know how to fix this problem? all the system check lights work just the back lights and the running lights dont turn on. if anyone can help id love you forever!
crmarie is offline
post #2 of 15 Old 02-20-2011, 06:33 PM
NUKEhead
NUKEhead's Avatar
2002 S/C Xterra
NUKEhead is on a distinguished road
I'm having the same EXACT problem, I'm not sure what's causing it, I have my dash apart re-doing my wiring trying to find a short somewhere. For me the first time it happened was almost exact with me turning my heat off.
Do you have any aftermarket electronics?
NUKEhead is offline
2002 S/C Xterra
post #3 of 15 Old 02-20-2011, 07:21 PM Thread Starter
crmarie
Just a radio other then that no. It happened right after I replaces the battery. When I turn the lights on it blows a fuse.
crmarie is offline
post #4 of 15 Old 02-20-2011, 07:31 PM
morpheus
2003 Xterra
morpheus is on a distinguished road
Check your fuses. If it keeps blowing fuses, if you have trailer wiring, check for corrosion in the connector.
Mike Thomson
Service Manager
Milton Nissan
www.miltonnissan.ca
morpheus is offline
2003 Xterra
post #5 of 15 Old 02-20-2011, 08:25 PM
miskywhisky
Quoted: 29 Post(s)
this!! I had the problem with a trailer one time, turned out to be a wire shorting out on the trailer. Good thing headlights are separate and i had my gps. Made it home with the hazards on.
miskywhisky is offline
post #6 of 15 Old 02-20-2011, 10:08 PM
Lucky13
Lucky13's Avatar
Lucky13 is on a distinguished road
thats why you should carry a headlamp in the truck :P
Lucky13 is offline
post #7 of 15 Old 02-20-2011, 10:11 PM
NUKEhead
NUKEhead's Avatar
2002 S/C Xterra
And how do you deal with a corroded connector?
Anyway besides replacing it?
NUKEhead is offline
2002 S/C Xterra
post #8 of 15 Old 02-21-2011, 09:34 AM
maxximus1210
maxximus1210 is on a distinguished road
Had the same problem with my 02 se/sc, there is a tech service bulletin about this issue, If you remove the right and left front marker lites and follow the wires they rub against the chassis and short out. hope this helps...=)
maxximus1210 is offline
post #9 of 15 Old 02-21-2011, 03:12 PM Thread Starter
crmarie
Thanks I'll try that. Hopefully it works.
crmarie is offline
post #10 of 15 Old 02-26-2011, 01:18 AM
kizzolie
kizzolie's Avatar
2002 XE Xterra
kizzolie is on a distinguished road
mine just started doing the same thing...any word on a fix? im gonna rip it apart tomorrow
-Kyyle
-=In Kizzolie We Trust=-
-Mr. President.
My Build Thread.
kizzolie is offline
2002 XE Xterra
