2000 Xterra 3.3 misfire at idle - Nissan Xterra Forum
post #1 of 9 Old 02-13-2011, 06:49 PM Thread Starter
bradwilfong
bradwilfong is on a distinguished road
My girlfriend just bought her new used 2000 Xterra 3.3 4wd 5 speed with 120000 miles! Signed the papers and before she got home the check engine light was on and when sitting at idle starts to flash! Original codes were p0300 random multiple misfire and p0325 knock sensor. First I ran some seafoam through the system, took it on a beat ride, then installed factory plugs replacing the 5 bosch platinum 2's and cylinder 6's original plug with no electrode left! No change at that point. After doing more research and talking to the Nissan dealer I installed a new factory distributor ordered by vin. Still no change. Installed factory wires with no change. Decided to tackle the knock sensor in hopes it was retarding the timing enough to cause the misfire. After new knock sensor, upper and lower intake gaskets, and a couple new coolant lines I took care of the knock sensor code!!!! Random misfire still occurring at idle, comes and goes at times. Decided to try the rest of the can of seafoam with hopes... denied! Any suggestions?
bradwilfong is offline
post #2 of 9 Old 02-13-2011, 07:40 PM
TJTJ
TJTJ's Avatar
Quoted: 191 Post(s)
Talking
Still no change.
Any suggestions?
Wow, you do bounce around once you get a head of steam up, don't you.
To get a few clarifications...
When you say "No Change", what do you mean?
Do you mean the truck is not running right, or, just that the codes have not reset yet?
You have already tracked down one of the common issues, that pesky #6 plug....the mechanics skip it because its a PITA, each thinking THEY are the first to do so, etc....
If the electrode is MISSING though, that does make one wonder where it is now though....?
My first thought is that its somewhere below where it started, which can certainly lead to trouble.
Another question...at 120K, it was due for a new timing belt and water pump at 105K....was that done?
Was it "Done" by the same consciousness chap who did the spark plugs?
As for the knock sensor...on the non-SC X's, its meaningless, and you could have ignored it. The O2 sensor, sure, makes the rig run crappy when they go south...but, the KS is not needed at all on that year X.
Given the questions on maintenance...a clogged air filter or crack in the intake plenum duct, a fouled MAF sensor, etc...could be present as well.
(And, your diffs and other lubes are probably dry or gunky, and so forth...but that's a separate issue...)
And, I can't help but ask...is there some reason you guys didn't bring it back to the guy who SOLD IT like that?
IE: It SOUNDS like it was "Code Cleared and Sold"...with the codes coming back right after the truck left the lot, etc....?
-TJ
TJTJ is offline
post #3 of 9 Old 02-13-2011, 08:28 PM Thread Starter
bradwilfong
By no change I mean it is acting just the same as before I did anything. I tell you it seems to run fine until you sit still at idle for a bit and even then the idle just gets a little rough and the check engine starts flashing. When scanned it is p0300 but the knock sensor code is gone! I was just being a smart ass about the electrode, I just meant it was very very warn. I did read a lot of places to ignore the knock sensor code but I had to give it a shot. I have changed the coolant and oil. I did not see any damage to the the plenum when I had it off but did not think to look over it too closely. I am unsure of the timing belt or water pump but I suppose that will be soon. I did clean the MAF today as well. As to returning it.... Was a cash deal from a person not dealer. We called the people and they gradually turned into not very friendly people...
post #4 of 9 Old 02-18-2011, 03:16 PM
CryptoX
CryptoX's Avatar
CryptoX is on a distinguished road
i have an 02 supercharged, and am having the same exact problem, i've replaced two o2 sensors cap, rotor, plugs, distributor, most of the vacuum lines, knock sensor relocation, intake air sensor, sea foamed and changed the oil. the timing and idle are dead on. It runs great going down the road but runs rough at idle and i get p0300 code. so if you figure something out let me know.
CryptoX is offline
post #5 of 9 Old 02-18-2011, 07:58 PM Thread Starter
bradwilfong
I did actually figure mine out. Everything I did needed done as everything was warn or done piss poor! I think the initial problem was the distributor, not just the cap and rotor, the whole assembly. The distributor bearing was warn. But the people I bought it off of did not have the most efficient mechanic. He changed the plugs but only did 5 skipping number 6 and he used after market plugs known to cause misfire codes. I suggest you use factory plugs. By TJ,s suggestion I thought maybe the same thrifty mechanic installed a timing belt. Sure enough it was a pretty new belt either installed a tooth off or slipped a tooth due to the warn tensioner. Not sure if that is possible, I think it was installed wrong! So I installed a new timing belt, tensioner, and water pump since I was in there! So with my new factory plugs, wires, distributor, knock sensor, timing belt, tensioner, water pump, and a few hoses I damaged! It runs great and my girlfriend loves it!!! Thanks for your suggestion TJ and I hope this helps you CryptoX!
post #6 of 9 Old 09-21-2014, 06:42 PM
devo_25
devo_25 is on a distinguished road
I am having the same problem with a 2000 frontier with a 3.3 motor, it is misfiring in cylinder #5 but its not giving me any codes, I know that its #5 because I did a power balance test and whenever I kill cylinder 5 the engine stays the same, I have power going to the plug and fuel going to the cylinder. any ideas?
devo_25 is offline
post #7 of 9 Old 03-21-2015, 11:05 PM
Relyt320i
Quoted: 1 Post(s)
2003 Xterra
Relyt320i is on a distinguished road
CryptoX, did you figure out your issue? I have an SC and having the same problem. I have put on new plugs, wires, rotor, cap, and MAF sensor . I had previously relocated the knock sensor. The car is driving better then it has in years but the idle is intermittently rough, sometimes perfect, sometimes rough, and sometimes rough like its missing. It has only thrown a pending misfire code for the number 4 cylinder but it ends up clearing itself before the check engine light comes on.
Not sure where to go next...
Relyt320i is offline
2003 Xterra
post #8 of 9 Old 03-23-2015, 07:05 AM
awesomekasim
Seasoned
awesomekasim's Avatar
Quoted: 6 Post(s)
awesomekasim is on a distinguished road
This link might help. It sounds like you have the same distributor bearing problem. My X is doing the same so I will be taking the distributor apart soon.
http://www.clubxterra.org/forums/showthread.php?t=22116
Nissan Driver
awesomekasim is offline
post #9 of 9 Old 04-01-2015, 11:06 PM
Relyt320i
Quoted: 1 Post(s)
2003 Xterra
Update on my rough idle. It got so bad one day that I stopped on my way to work to have it checked out. Turns out I had an injector that was going bad. Replaced and the idle is fine.
Now my issue is low or no boost out of the SC when I fill up with gas. It will also miss slightly under load but very intermittently. It really makes driving crappy. At around half a tank I get full boost and it runs great. No codes are pulling. I am scratching my head on what this could be. I always use premium gas from shell or chevron. I know that there are a few things that trip the sc to into fail safe mode and prevent boost but why would the first half of a tank be crap and the second be perfect. The only idea I had was maybe the EVAP system but I assume that would throw a code...
Any ideas would be great.
2003 Xterra
