Service engine soon light - Nissan Xterra Forum
post #1 of 9 Old 12-22-2010, 07:20 PM Thread Starter
capnp72
2005 Xterra
I have a service engine soon light on my '05. If I disconnect the battery for 30 min will it go out if there are no codes? How else could I make the light go out? I don't have a code reader.
capnp72 is offline
2005 Xterra
post #2 of 9 Old 12-22-2010, 07:29 PM
Bwedel24
Seasoned
Bwedel24's Avatar
advance auto will let you use theirs for free... just ask for it and hand them your license.
wedel
2002 Silver Xterra 4x4 ~ 105,xxx
BILSTEIN 5100s and AC shackles, Cobra 19DXIV CB w/ PA speaker behind the bumper, Firestik II w/ fold over adaptor (for the parking garage!), Resonators removed, Xterra Neoprene Seat Covers. Calmini IAB. Nobody gives a shit but rear swaybar removed and headliner fixed!
Not a build thread yet but its all i've got:
http://www.clubxterra.org/forums/showthread.php?t=25199
http://www.clubxterra.org/forums/showthread.php?t=25125
Bwedel24 is offline
post #3 of 9 Old 12-22-2010, 07:56 PM Thread Starter
capnp72
2005 Xterra
I disconnected the battery for 30 minutes and the light didn't come back on.
capnp72 is offline
2005 Xterra
post #4 of 9 Old 12-22-2010, 08:03 PM
cbxterra
Quoted: 31 Post(s)
Garage
I have tried the disconnect trick a couple of times in my old truck. It sort of worked for awhile [2-3 months]. Try changing the oil first maybe? My car is doing that and i know it's because i'm too bloody busy to change the oil. One thing about disconnecting the battery- write down all your radio stations first [hard to remember afterwards- been there did that] [then lost the t shirt]. Also it's always good to have your radio theft code handy too [otherwise it won't work on startup]. But it can't hurt to try. When I did it I left it off overnight then just hoooked up, rebooted the radio and drove away.
cbxterra is offline
post #5 of 9 Old 12-22-2010, 10:31 PM
soccerbrace
blah blah blah
soccerbrace's Avatar
Quoted: 1 Post(s)
Or you can find out what the code is so we can help you.
Photobucket
soccerbrace is offline
post #6 of 9 Old 12-23-2010, 04:46 AM
rjr162
rjr162's Avatar
Quoted: 1 Post(s)
x2 with Soccer
capnp72: That's great and all that you got the code to go away, but unless you know the code was thrown because of you (as in you had a fuel injector unplugged, forgot, and started the car but have since plugged the injector back in) it may not have been the best to clear the code. Without the code you don't know what's wrong, and that's not a good thing
rjr162 is offline
post #7 of 9 Old 12-23-2010, 08:13 AM
CMD
\m/>_<\m/
2003 Xterra
The light doesn't just come on for the fun of it. Something is wrong with your car, unless you haven't come to the conclusion of what service engine soon means...
- Sean
Totaled - 2003 XE - 3" SL, 2" BL, Sliders and Skids, 33" MT's
Build Thread - Warthog
http://www.clubxterra.org/forums/showthread.php?p=515519#post515519]"Second X"
Ohh, Second Gen? Typical....
CMD is offline
2003 Xterra
post #8 of 9 Old 12-28-2010, 07:12 PM
Trishness
Trishness's Avatar
My SES light went on back on December 11th and fuel gauge wasn't registering correctly.....filled the X with gas and still was registering 1/4 tank. SES light went off after a couple of days but came back on next fill up. Found out it was the Fuel Level Sensor/sending unit. ERROR CODE P0463. Nisan has not issued a full recall for this but extended the warranty from 36K/36 months to 72K/72 months on CERTAIN vin#s. Not sure if this helps but I had mine replaced for FREE at my local Nissan Dealership today.
Trish
Trishness is offline
post #9 of 9 Old 12-28-2010, 10:32 PM
Cyclemut
Most Halal Mod
Quoted: 2 Post(s)
02 Xterra
Disconnecting your battery also clears the self-learn in the computer, resetting anything that it's learned. So resetting the light like that isn't recommended.
Get the code pulled. You might be hurting your engine or transmission by ignoring it.
A little bit spent now might save you from spending a ton later!
Cyclemut is offline
02 Xterra
