Know issue, no luck! Heater blowing cold air... - Nissan Xterra Forum
post #1 of 10 Old 12-19-2010, 10:24 PM Thread Starter
aliengin
OK, before anyone says anything I did my search and found a lot of posts on the web with the same problem. Answer seems to be the cooler!
Its a 08 Xterra Off Road
Here is my problem:
Heater blows cool air not like AC but more like fan air when the car is not moving. You can feel it even when stopping at red lights. Once the car starts moving heat turns on. Also when the car is moving I can smell the fume like almost the heat is coming from engine department without any filtration, this happens even if I select circulate cabin air button.
Cooler was at the minimum level in the small reservour.
This is what i did:
I filled the reservoir to max level, and topped the radiator. Put the car on a ramp lifting front end, open the valve and run the engine for 15 minutes about 2000 rpms. I also turn the heat all the way up. After the process topped the radiator and filled the reservoir again to max. Drove for 20 minutes and problem still existed.
Second solution took the car to dealer and told them the problem. They said they didn't have the mechanic on Saturday but they told me they checked the pressure level in the rediator and couldn't find any problems.
Car does not over heat but again I am in Chicago and its around 15s! I checked the cooler again today and seems like it lost some since Friday. Level was a litle under Minimum level.
Its obvious that its loosing from somewhere and heater is sucking air from engine compartment. One other thing is when i turn the engine off if the heat is on I can hear some water bubling right behind the dashboard.
I am going to take the car to another service this week. Does anyone know what this could be?
Thanks.
aliengin is offline
post #2 of 10 Old 12-19-2010, 11:59 PM
ASTE25
ASTE25's Avatar
2011 S 4X4 Xterra
I thought we cleared this up. lol.
ASTE25 is offline
2011 S 4X4 Xterra
post #3 of 10 Old 12-20-2010, 07:45 AM Thread Starter
aliengin
I know I know. I am just trying to get more feedback about this, maybe someone had the same problem. My only concern is I am going to leave the truck at the dealer and they are going to turn the heater on IN THE HEATED SERVICE AREA (which they did on Saturday) and tell me nothings wrong with it.
BTW, I checked the floor this morning and there was no neak overnight. I drove about 10 miles and i will check the reservoir tonoght to see the fluid level.
aliengin is offline
post #4 of 10 Old 12-20-2010, 08:56 AM
S2X01
S2X01's Avatar
thermostat?
Stu.
'01 Silver XE
Got Some Mods.....More comin.
BUILD THREAD
http://www.clubxterra.org/forums/showthread.php?t=16390
That's it, I'm gonna start carrying my muzzle-loader in the rig. Ain't no sneakin' up on me!
Of course there's always been a rivalry between Blackfoot and the Shoshone tribes anyway. Indian signs getting thrown around and my wife looking at me like I'm the idiot. I mean really, someone flashes me 'Your mom looks like a doe's ass' sign and it's on!
S2X01 is offline
post #5 of 10 Old 12-20-2010, 12:16 PM
ASTE25
ASTE25's Avatar
2011 S 4X4 Xterra
It won't matter if they turn it on in their heated shop. All that matters is that the heat is on and the water is allowed to flow through the heater core to purge the air. Even in the shop the heater when working correctly should be a lot hotter than the ambient air in the shop. Let me know what you find out.
ASTE25 is offline
2011 S 4X4 Xterra
post #6 of 10 Old 12-20-2010, 12:24 PM
Itsme
Itsme's Avatar
Quoted: 1 Post(s)
2000 4x4 Xterra
just some thoughts:
It could be the heater core is leaking and needs to be replaced. This could cause the engine compartment smell you talked about. It could also just be a heater hose leaking on the firewall and getting into the heater.
The fact that it is cold at while stopped and at idle, could be to air in the system, filling the heater core with air and not coolant.
Itsme
Itsme is offline
2000 4x4 Xterra
post #7 of 10 Old 12-20-2010, 10:06 PM
ASTE25
ASTE25's Avatar
2011 S 4X4 Xterra
Good point about the smell. He mentioned it, but said it smelled like engine fumes. I could see now how someone might describe the smell of coolant like that.
ASTE25 is offline
2011 S 4X4 Xterra
post #8 of 10 Old 12-22-2010, 11:01 AM
ASTE25
ASTE25's Avatar
2011 S 4X4 Xterra
Well, what was the verdict? Did you take it in yet?
ASTE25 is offline
2011 S 4X4 Xterra
post #9 of 10 Old 12-22-2010, 11:29 AM
BakerX05
Seasoned
BakerX05's Avatar
2005 Xterra
try this
http://www.thenewx.org/forum/showthread.php?t=24370
Baker
'05 Granite SE 4x4|AJ SS Rock Slider|PRG 3" suspension lift|285/75r16 Yokohama Geolander MT+|Pro Comp 7089-6868|PIAA 520 ATP|Shrock rear bumper w/tire carrier|NXrocks Skids|IMS|Flip Kit| Baker's X
BakerX05 is offline
2005 Xterra
post #10 of 10 Old 01-11-2011, 04:43 PM
jacarpenter
2005 Xterra
I have an 05 and its doing the exact same thing. Did you find out what the problem was. I really dont want to spend tons on money at the dealer when it is probably a simple fix.
jacarpenter is offline
2005 Xterra
