cost to replace fast idle hose? - Nissan Xterra Forum
post #1 of 18 Old 12-02-2010, 08:46 AM Thread Starter
cajun jamie
Seasoned
cajun jamie's Avatar
cajun jamie is on a distinguished road
Hi all,
A couple months ago my fast idle adjuster was leaking so I replaced the O-ring and it is fine. However, the coolant hose that attaches to it has weakened and leaks at the clasp. I do not think there is enough hose to snip off the end and re-attach it. I may try using a hose coupler and a piece of new hose.
This is the hose that goes on the throttle body and pumps coolant in.
Can someone tell me the name of this hose? I did an Internet search but could only find the fast idle assembly and not the hose. Is this hose difficult to replace?
Thanks!
Jamie
cajun jamie is offline
post #2 of 18 Old 12-02-2010, 12:25 PM Thread Starter
cajun jamie
Seasoned
I bought a section of hose at lunch today and now am wondering if anyone knows if that 3-inch section of rubber hose from the throttle body to the metal tubing can just be removed and replaced, or is it sealed to the metal tube?
post #3 of 18 Old 12-09-2010, 03:08 PM Thread Starter
cajun jamie
Seasoned
bump ^
Anyone know if I can just pull off that 3-inch hose section going to the throttle body, or will that ruin the tubing and hose seal?
post #4 of 18 Old 12-09-2010, 03:18 PM
soccerbrace
blah blah blah
soccerbrace's Avatar
Quoted: 1 Post(s)
soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold
http://www.courtesyparts.com/xterra-...4_467_471.html
Try finding it on this page and hover over the part. When you hover, the proper name will show up
Photobucket
soccerbrace is offline
post #5 of 18 Old 12-09-2010, 03:45 PM Thread Starter
cajun jamie
Seasoned
Thanks.It was not in that diagram, but in another, it is called the Idle Control Valve.
The image below is my throttle body. beside the body is the valve that was leaking. The metal tube on the bottom left with the black coating is the tube that pipes in water from the radiator through this valve. At the end of the metal tube carrying radiator fluid is 3 inches of rubber hose. Mine leaks and there is no slack to trim the tube and re-connect. I'll try and snap a shot of this on the truck and post later. I fixed the O-ring on the valve. Now the rubber hose connecting to it is leaking and needs to be replaced.
Thanks!
jamie
post #6 of 18 Old 12-09-2010, 04:29 PM
soccerbrace
blah blah blah
Quoted: 1 Post(s)
Cool! Glad I helped Jamie! Good to have you here
Photobucket
post #7 of 18 Old 12-09-2010, 09:14 PM
outwiththeold
outwiththeold's Avatar
Quoted: 6 Post(s)
2000 XE Xterra
looks to be a straight hose.
warn manual hubs,PML, and a ditched rear sway bar.K&N Drop w/ resonators removed.Plastics Repainted Black.
outwiththeold is offline
2000 XE Xterra
post #8 of 18 Old 12-16-2010, 11:21 AM
aagill225
Seasoned
aagill225's Avatar
aagill225 is on a distinguished road
looks that way, where did you get the O-ring? i need to do mine. Did you realy need to remove the entire intake?
aagill225 is offline
post #9 of 18 Old 12-16-2010, 12:51 PM Thread Starter
cajun jamie
Seasoned
The O-ring I purchased at the local parts store. I removed the valve and took it to the store to match it up with an O-ring.
You do not have to remove the entire assembly, but because that was my first time and I had no idea what was involved, I removed the assembly because it is quite simple to. Detach a few hoses and I think 4 nuts and it's off.
To do it with the assembly attached, get about a 6-10 inch piece of coat hanger wire, cock the spring lever wide open, wire it up to stay back and then just remove the valve and replace the O-ring.
Be sure to check the bottom hose for leaks, it can get soft at the connection and leak as well. That is what I need to address. That bottom hose is so short, i am not sure if I can snip the end and still have enough left to reach the connection.
post #10 of 18 Old 12-16-2010, 07:30 PM
aagill225
Seasoned
aagill225's Avatar
my hose and vaulve have leaked since i purchased it. I would always see a wet spot
(:0) but could not see where it was coming from until i actualy caught it dripping. Took it apart after that to replace the clamp with a new one but was the wrong size. to lazy to redo i guess. LOL leak is minamal
