Popping Noise: Front Passenger Area - Nissan Xterra Forum
post #1 of 7 Old 12-01-2010, 09:51 PM Thread Starter
chuckamazuk
chuckamazuk's Avatar
chuckamazuk will become famous soon enough chuckamazuk will become famous soon enough
Hey all. I have a "popping" sound coming from my front passenger area. It mostly happens when accelerating/braking quickly and the front end goes up and/or down. It also happens while rolling down the road (as the wheel must move up and down with the road). I recently upgraded my steering (HooHaa CL, Bandit IA Bushings, new TRE/TRA's) and thought it might be that. I've double checked that all my fasteners are tight and that nothing is loose. If i roll slow with no accelearation or stopping on a flat surface I can yank on the steering left to right and back and the "pop" does not happen. I keep thinking it may be the steering stuff but I may have started to hear this before I messed with the steering. It is getting more noticeable; however, it does not happen all the time. Often during up/down motion it is silent and other times just a small rise or fall with make the sound. Any ideas on what I should start looking at?
Chuck
Armor: Custom Sliders [built by me] - RLC Front Bumper - Skidrow Front, Eng/Trans, and TC skids
Lift: PML (AC) - 2" BL (DIY)
Lighting: PIAA 525 x 2 & Hella FF75 x 4
Steering: Calmini IAB - Bandit4x4 IAB Bushings - HooHaa CL - AC HD TRAs
Tires: 285/75R16 DuraTracs
Winch: ENGO E10000S
Write-Ups: Shocks & IAB :: "Homelink" :: Custom Light Bar :: Power Inverter :: Wiring
Build Thread
chuckamazuk is offline
post #2 of 7 Old 12-02-2010, 06:07 AM
Itsme
Itsme's Avatar
Quoted: 1 Post(s)
2000 4x4 Xterra
Itsme will become famous soon enough Itsme will become famous soon enough
It almost sounds like the torsion bar needs to be tightened down at the A arm. At least it is worth the check.
Itsme
Itsme is offline
2000 4x4 Xterra
post #3 of 7 Old 12-02-2010, 06:48 AM
TJTJ
TJTJ's Avatar
Quoted: 192 Post(s)
Talking
The best way to check is to have a buddy in the drivers seat, while you look/listen down below...
and have them turn the wheel back and forth.
On the Hoo Hah/steering issues, it will clunk if its wallowing out, etc....if you get a clunking noise, etc....you can trace it to its source...looking from the pitman arm down.
The other thing is the sway bar/brackets/bushings...they commonly get loose with wear as well. A visual inspection will typically reveal that, looking at the entire set-up from the LCA links, bar ends, and cross member brackets, etc.
If you suspect that the t-bar anchors are becoming unbolted, a visual inspection will typically reveal evidence of movement/wear at these points as well.
Jacking the front end up, and manually raising and lowering the tires, and shaking them in/out at the tops, and then at the fronts, can also help see if tie-rod ends or ball joints might be making noise as well (Cries for help).
If you have skid plates, sometimes they get jammed so as to pop in/out of position as the frame flexes over the road...visually, this can be hard to see unless you notice a wear mark where plates overlap, etc, or bolts are loose, etc.
Anyway - the above are decent starting points.
-TJ
TJTJ is offline
post #4 of 7 Old 12-02-2010, 06:56 AM Thread Starter
chuckamazuk
Thanks for the pointers, guys. I'll start with those and will report back.
Chuck
Winch: ENGO E10000S
Build Thread
post #5 of 7 Old 12-20-2010, 03:22 AM
skeeter2221
skeeter2221 is on a distinguished road
Did you ever find out where the noise is comming from?
skeeter2221 is offline
post #6 of 7 Old 12-20-2010, 09:04 AM
fusionfronty99
fusionfronty99's Avatar
Quoted: 2 Post(s)
99' Xterra
fusionfronty99 is on a distinguished road
its your lower BJ going bad
Got an xterra with a bed...
fusionfronty99 is offline
99' Xterra
post #7 of 7 Old 12-20-2010, 10:57 AM
chainring
chainring's Avatar
chainring will become famous soon enough
^^I was thinking LBJ too. Sounds a little like what mine was doing. I could hear it when I shook the front wheel from the top.
2001 2wd
PML / Bilsteins /NISMO CAI & cat-back exhaust / 31" Yokohama Geolander ATs / PIAA headlight bulbs / Hella 500 FF w/ Silverstar bulbs on the roof / Hella Optilux on the bumper / LED corner lamps / Painted Rack, step tubes, and wheels
"All your base are belong to us."
chainring is offline
