Knock Sensor relocation problem - Nissan Xterra Forum: Xterra Forums
Old 11-19-2010, 11:21 PM
Pumpkin's Avatar
Pumpkin Pumpkin is offline
Seasoned
Member: #11068
2003 Xterra
Pumpkin is on a distinguished road
I just replaced my supercharger, because it was really noisy. The new one seems to be working great (much quieter). I previously had my knock sensor relocated, to the the side bolt of the s/c. I was still getting low boost and lack of power. My mechanic removed the sensor from the side of the s/c, ran a ground wire from the sensor directly to the negative side of battery, and wrapped the sensor (in bubble wrap??) Anyhow This worked great but looked like crap. I was wondering, would it hurt anything to still have it bolted to the s/c, but also have a separate ground wire running to the negative battery terminal? This is the only solution I can think of to get a proper ground.
Old 11-19-2010, 11:38 PM
J Everett's Avatar
J Everett J Everett is offline
Member: #4974
2008 Xterra
J Everett is a jewel in the roughJ Everett is a jewel in the roughJ Everett is a jewel in the rough
Just my 2¢, but if it works I wouldn't care how it looks. Who's gonna be looking under your hood?
--Jason
My 2008 Super Black SE "The Elephant"
The ass of my ride will swap ends faster than the OP will fail an English class.
Old 11-20-2010, 10:39 AM
Dragon X's Avatar
Dragon X Dragon X is offline
IYAAYAS
Member: #9600
04 Xterra
Dragon X is on a distinguished road
I had the same problem. So I just ran the ground wire to the eng block and tied the knock sensor back to the harness with some zip ties and e tape. You can't even see it
2004 SILVER ICE SE/SC
-3" A/C SL With HD Bilsteins -2" DIY BL
-GRASSROOTS CENTERLINK-2.4 PULLEY -INTAKE MOD WITH K/N DROP IN-2 KC DAYLIGHTERS 2 HELLA 500FF,-CONCEPT-CUSTOMS LIGHT BAR-COBRA CB W/FIRESTICK.-SUPER CUSTOM BUMPER CHOP
Build Thread
Old 11-21-2010, 02:34 PM
F150Boss86's Avatar
F150Boss86 F150Boss86 is offline
Member: #1966
03 Xterra
F150Boss86 is on a distinguished road
were you still throwing a code with out the ground? I have mine bolted to the SC bolt on the right side also, but I didn't run a separate ground wire...but Im also not throwing a code...
2003 Nissan Xterra SE Supercharged, 1.5" Spacers, KS Relocation, Aux. Lights for roof, bumper, and rear, sway bar removal, AAL, PML
http://www.clubxterra.org/forums/showthread.php?t=16837
Old 11-22-2010, 07:48 PM
Pumpkin's Avatar
Seasoned
Member: #11068
2003 Xterra
I added the ground wire today, it didn't seem to work though. I still have the same lack of boost/power. No codes. I'm thinking removing it from the engine altogether might be the only option, but I kinda want it to be functional still. I don't like the idea of the engine knocking and blowing up because there's no knock sensor. Any other locations that might work?
Old 11-22-2010, 09:57 PM
RockMozart13's Avatar
RockMozart13 RockMozart13 is offline
Member: #5030
'02 SE S/C Xterra
RockMozart13 is on a distinguished road
you replaced the supercharger and didn't throw in a knock sensor? are you sure you got a good one? I've heard the $20 ones off ebay practically come dysfunctional.
2002 SE S/C Sedona
XOC/LINXC Member Since '04
Goodyear Wrangler ATS 275/70/17, PML, Intake Resonators Removed, Drop In K&N, Flowmaster Cat-Back, Rancho RS5000s, LOBO Rack, Interior LED Map/Dome Lights
To Do: Repaint Plastics(Again), Custom Sliders, Knock Sensor Relocation, SoundRacer V8 Mod
Wishlish: 32" ATs, PML, 2" BL, Sliders, UCAs,
Facebook Photo Bucket
Old 11-23-2010, 07:29 PM
F150Boss86's Avatar
Member: #1966
03 Xterra
how could it be pulling boost but not throwing a code??? I figured that if the code wasnt there then everything was fine...I hope mine is ok!
  #8
Old 02-03-2011, 11:47 AM
kriskool123's Avatar
kriskool123 kriskool123 is offline
Seasoned
Member: #4491
03 Xterra
kriskool123 is on a distinguished road
Does this Knock sensor relocation allow for more "safe boost"
looking for:
1.USED front and back diff gears 4.88 or 5.13
2.USED ARB front and rear locker
  #9
Old 02-04-2011, 04:26 AM
frontyfan's Avatar
frontyfan frontyfan is offline
Member: #7519
frontyfan is on a distinguished road
no, a bad KS prevents you from getting the actual boost you are supposed to. It limits you to about 2lbs instead of the 5 or 6lbs (can't remember off the top of my head).
It costs about $900 to have a stealership replace the KS due to it's location. Relocating it is cheap, but about a 50/50 chance of actually working properly (from the research I have done, it's been 50/50. Relocating allows you to get the boost you should be getting from the factory). I relocated mine to the SC and would get one good run before it would go back to fail safe mode, I sinced deployed so I haven't been able to find a better location.
SOLD
My Frontier
  #10
Old 11-11-2012, 05:01 PM
Gabito Gabito is offline
Member: #36992
Gabito is on a distinguished road
Exclamation Knock sensor relocation
Hi, I relocate the knock sensor in the side of the supercharger one day ago. And my X still having the lack of power/boost. The KS is nissan genuine. With a voltimeter I see the KS is sending 2 volts at idle. And with the engine off has a 280 Mohm of resistance. Are this numbers good? The change in power/boost are fast after the relocation?
