New guy question-VERY high oil pressure on gauge? - Nissan Xterra Forum
post #1 of 15 Old 10-27-2010, 09:18 PM Thread Starter
UTXterras
2006 Xterra
UTXterras is on a distinguished road
Hello everyone, this is my first post on these boards and I'm glad I found this site! I've been lurking for a while and I've searched for an answer to my question but haven't found an answer. I have an 06 Xterra Off Road with 96000 miles on it, we bought it a few months ago and love it!
I noticed the other day that the oil pressure gauge is reading very high-it's at the top of the gauge when the engine is running and it doesn't move with engine RPM or temperature. If you turn the key to ON it stays just below the H mark on the gauge, but as soon as you start the engine it jumps to the top of the gauge. The engine oil level is normal and I just changed the oil and filter about 300 miles ago. What do you guys think, I'm kind of stumped on this one!
Thanks for any advice!
UTXterras is offline
2006 Xterra
post #2 of 15 Old 10-27-2010, 09:50 PM
helifixerupper
helifixerupper's Avatar
helifixerupper is on a distinguished road
my a bad pressure sensor? Are you getting a check engine light?
2002 XE 4x2--Flowmaster 40 Delta--High Flow Custom Intake--Complete stereo make over--Custom Lightbar w/ HID's
- Brian
helifixerupper is offline
post #3 of 15 Old 10-27-2010, 10:50 PM Thread Starter
UTXterras
2006 Xterra
No check engine light, which is what was puzzling me. Am I risking damage to my seals and gaskets by driving with high oil pressure?
2006 Xterra
post #4 of 15 Old 10-28-2010, 06:32 AM
NCPhotoTrekker
NCPhotoTrekker's Avatar
2010 Xterra
NCPhotoTrekker will become famous soon enough NCPhotoTrekker will become famous soon enough
Me thinks that sunshinelehua is a spammer that is stealing other posts in order to sell Louis Vutton Handbags. While they go great with an Xterra, I don't think that we need to suffer through the advertising...
Greg
4x4 in all caps is $X$
NCPhotoTrekker is offline
2010 Xterra
post #5 of 15 Old 10-28-2010, 06:49 AM
Jmac289GT
Jmac289GT's Avatar
Jmac289GT is on a distinguished road
Man that had me tripping for a bit...I read both post twice.
I would venture to say a bad oil sending unit too, I would try that first if your going to start guessing at things.
Jmac289GT is offline
post #6 of 15 Old 10-28-2010, 07:46 AM
TJTJ
TJTJ's Avatar
Quoted: 190 Post(s)
Talking
The psi should change with rpm, etc...if it doesn't, the gauge, or the sensor, is probably malfunctioning.
-TJ
TJTJ is offline
post #7 of 15 Old 10-28-2010, 08:25 AM Thread Starter
UTXterras
2006 Xterra
Thanks for the replies guys, my thought was the sensor too but not getting a check engine light is what I couldn't figure out. I'll look into replacing the sensor, according to the FSM it should be pretty easy, has anyone else done theirs?
2006 Xterra
post #8 of 15 Old 10-28-2010, 02:09 PM
Itsme
Itsme's Avatar
Quoted: 1 Post(s)
2000 4x4 Xterra
Itsme will become famous soon enough Itsme will become famous soon enough
I agree with the sender or guage malfunction!
Itsme
Itsme is offline
2000 4x4 Xterra
post #9 of 15 Old 10-28-2010, 03:18 PM Thread Starter
UTXterras
2006 Xterra
Getting a new sensor ordered today, looks like a pretty easy install so hopefully that will take care of it. Thanks again guys!
2006 Xterra
post #10 of 15 Old 11-09-2010, 11:02 AM Thread Starter
UTXterras
2006 Xterra
Update-replaced the sensor and everything seems to be fine. Gauge reading normal, etc. Thanks for the help guys!
2006 Xterra
