What kind of battery do I need? - Nissan Xterra Forum
post #1 of 11 Old 10-25-2010, 01:59 PM Thread Starter
morganology
morganology is on a distinguished road
Hi there, my battery died today.
What kind of battery do I need for a
2001 Nissan XTerra
4x2
XE
116k miles.
Thank you!
morganology is offline
post #2 of 11 Old 10-25-2010, 03:47 PM
soccerbrace
blah blah blah
soccerbrace's Avatar
Quoted: 1 Post(s)
soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold
I'd go for a 12 volt personally. Go to the store and they will get you set up right
Photobucket
soccerbrace is offline
post #3 of 11 Old 10-25-2010, 04:22 PM
chainring
chainring's Avatar
chainring will become famous soon enough
Go see your friends at Auto Zone, Advanced Auto, O'Riely, etc. Most will even put them in for you if you want. I've had good luck with Auto Zone mid-grade batteries over the past several years.
2001 2wd
PML / Bilsteins /NISMO CAI & cat-back exhaust / 31" Yokohama Geolander ATs / PIAA headlight bulbs / Hella 500 FF w/ Silverstar bulbs on the roof / Hella Optilux on the bumper / LED corner lamps / Painted Rack, step tubes, and wheels
"All your base are belong to us."
chainring is offline
post #4 of 11 Old 10-25-2010, 05:56 PM
xearth
xearth's Avatar
xearth is on a distinguished road
I just call around and pick up the cheapest battery they have and I have had no problems. (running 1000 watt sound system and 4 offroad lights in addition to stock)
xearth is offline
post #5 of 11 Old 10-26-2010, 12:12 AM
raiderfernie
Seasoned
raiderfernie is on a distinguished road
I have a 25 series battery on mine that i purchased in 09.
our trucks allow for several series battery to go in...a 24 series, 25, and 26. 25 and 26 series are shorter while the 24 is longer. all three should fit, its your decision. if you want to get the same size you have right now.
as noted in another reply, any auto parts store should help you out.
if you want to op for a stronger battery go ahead, will come in handy in winter months; however, more amps more money.
raiderfernie is offline
post #6 of 11 Old 11-22-2010, 01:15 AM
krovikan21
krovikan21's Avatar
04 SE N/A Xterra
krovikan21 is on a distinguished road
http://www.sears.com/shc/s/p_10153_1...1&blockType=L1
im about to pull the trigger on this guy series 34 fits too!
04 SE W/ PML, Resonators/Baffles Removed, Sway Removed, Bilstein Shocks for 3", Shrock front(ordered), HID Roof Lights, Alpine Amp W/ Rockford 12", K+N Filter, Shrock Sliders, Viper 5701 Remote Start/ Alarm (Self Installed w/ CX help of course), IAB, Tire Pulley Removed. Heated Drivers Seat
HID build threadhttp://www.clubxterra.org/forums/showthread.php?t=18007
Heated Seat DIY:http://www.clubxterra.org/forums/showthread.php?t=24875
krovikan21 is offline
04 SE N/A Xterra
post #7 of 11 Old 11-22-2010, 10:34 AM
RawkerStatus
RawkerStatus's Avatar
RawkerStatus is on a distinguished road
200?!?! ouch. go to walmart. much cheaper and probably better warranty.
Conveniently off the 10 and 210 in San Dimas... no not really
RawkerStatus is offline
post #8 of 11 Old 11-22-2010, 06:43 PM
sionnach
2000 v6 SE Xterra
sionnach will become famous soon enough
For that kind of $$ why wouldn't you go for a Optima yellowtop?
Todd
Seattle, WA
~85k miles (nov 2010)
[X] RED LED map lights [X] Thor Mod [X] PML [ ] Total Chaos IAB [X] Bilsteins [X] 32x11.50R15/C BFG A/T KO [ ] Tail Light Covers [ ] lighting package (top bar and bumper mount) [ ] UCA & AAL to finalize SL
[ ] Shrock front bumper [ ] “ Rock sliders [ ] “ Front skid plate [ ] “ Engine skid plate [ ] “ Tcase skid plate [ ] “ Gas tank skid plate [ ] “ Rear bumper [ ] Convert all stock lights to LED
sionnach is offline
2000 v6 SE Xterra
post #9 of 11 Old 11-22-2010, 06:59 PM
Lucky13
Lucky13's Avatar
Lucky13 is on a distinguished road
x2
as i see it you have 3 choices
1. cheap stock watt batt from wherever is cheap.
(most sulfuric acid batts will all last about the same with maintenance)
2. 1000 watt cheap batt
3. Optima batt
(have some kind of gel if i remember correctly, so they work correctly upside down and wont spill. they also last at least twice as long)
i went with 2 (they all work and create 12 volts)
Lucky13 is offline
post #10 of 11 Old 11-22-2010, 07:09 PM
Cyclemut
Most Halal Mod
Quoted: 2 Post(s)
02 Xterra
Cyclemut has a spectacular aura about them Cyclemut has a spectacular aura about them Cyclemut has a spectacular aura about them
Well morganology, since you're in LA and you don't have to deal with the bitter arse cold that kills batteries, I'd just go back with the stocker. Any parts store will be able to hook you up with minimal outlay.
Unless you have a huge stereo, a ton of lights, maybe a refrigerator in the back for those Anzo camping trips, then I'd just stick with the stocker. Otherwise, a nice yellowtop or dry cell (even a gell cell) will work nice for the larger draws.
Cyclemut is offline
02 Xterra
