p0430 & p0328 - Nissan Xterra Forum
post #1 of 21 Old 09-26-2010, 04:01 PM Thread Starter
phrog man
Chrome can go to hell
phrog man's Avatar
Quoted: 1 Post(s)
phrog man will become famous soon enough
p0430 & p0328
From what i understand the easiest trouble shoot to this is to replace the grounding wire bolt on the drivers side manifold as it could be rusted or damaged in some way. i have inserted a picture so someone can help me confirm that I'm looking at the right bolt. The code mentions the term (bank 2) and i honestly have no idea what that means and hope someone can clarify please. On a side note i have recently removed and replaced the throttle positioning sensor and MAF sensor and the air filter for cleaning. After this the X now idles at 600 rpm's. This seems low maybe too low which leads me to believe that it is not associated with the codes, but I'm not sure. I have also read that these codes mean I'm running rich, I have not done a full tank test but, it seems like the X is burning up a lot more fuel than usual and the smell from the exhaust seems to smell like fuel. Would exhaust leaks cause me to burn rich, or a sensor?
it looks like the wire is pretty frayed... Problem?
2004 BLACK X-AUTO
Build Thread
phrog man is offline
post #2 of 21 Old 09-27-2010, 05:24 AM
dmcc
dmcc is on a distinguished road
If the TPS was not put back in the same posistion as when it came off your idle could get messed up. There is some play/ adjustment on the mounting bracket with the TPS. There is a detailed way of setting the TPS with volt meter in the Haynes manual.
dmcc is offline
post #3 of 21 Old 09-27-2010, 06:14 AM
dejablue
dejablue's Avatar
Quoted: 242 Post(s)
2003 Xterra
dejablue is a glorious beacon of light dejablue is a glorious beacon of light dejablue is a glorious beacon of light dejablue is a glorious beacon of light dejablue is a glorious beacon of light
yes the ground looks bad what does the other end look like that the side that is the propblem?
Dennis
dejablue is offline
2003 Xterra
post #4 of 21 Old 09-27-2010, 11:09 AM Thread Starter
phrog man
phrog man's Avatar
Quoted: 1 Post(s)
alright ill look into the procedure. does that idle seem bad though?
2004 BLACK X-AUTO
Build Thread
post #5 of 21 Old 09-27-2010, 11:11 AM Thread Starter
phrog man
phrog man's Avatar
Quoted: 1 Post(s)
the other end looks great but, im going to replace the whole thing wire and all
2004 BLACK X-AUTO
Build Thread
post #6 of 21 Old 09-27-2010, 01:26 PM
dmcc
phrog man, The Haynes manual says idle is 750 rpm, so yours sounds a bit low. I know mine is around 700-750 on the tach guage in the instrument cluster and it has a little miss every so often and the tach is reading 600-650rpm's when that happens. Idle gets a little rough.
dmcc is offline
post #7 of 21 Old 09-28-2010, 06:28 PM Thread Starter
phrog man
phrog man's Avatar
Quoted: 1 Post(s)
well got into an accident yesterday so ill post up how the grounding wire goes as soon as i can.
2004 BLACK X-AUTO
Build Thread
post #8 of 21 Old 10-03-2010, 10:08 PM Thread Starter
phrog man
phrog man's Avatar
Quoted: 1 Post(s)
alright so with closer inspection one end of the ground was almost completely severed. after going to Nissan and finding out that the grounding wire comes with a whole wiring harness that costs a couple hundred dollars i put together a grounding wire to replace it. the original bolt that secures to the heat shield broke so i had to use a manifold mounting stud instead. ill post up if the check engine light turns off.
[IMG][/IMG]
8guage
ill try to get a better one later if it works
2004 BLACK X-AUTO
Build Thread
post #9 of 21 Old 10-19-2010, 03:36 PM Thread Starter
phrog man
phrog man's Avatar
Quoted: 1 Post(s)
no go
cel came back on, no go on the bigger better ground wire. trying sea foam next.
2004 BLACK X-AUTO
Build Thread
post #10 of 21 Old 10-19-2010, 03:44 PM
dejablue
dejablue's Avatar
Quoted: 242 Post(s)
2003 Xterra
how many miles did you drive?
Dennis
dejablue is offline
2003 Xterra
