Snapped off a heater core tube :( - Nissan Xterra Forum
post #1 of 26 Old 08-14-2010, 02:22 PM Thread Starter
zachbiz
zachbiz's Avatar
zachbiz will become famous soon enough zachbiz will become famous soon enough
So last night when i took the X out for the first time after the body lift, it started spewing steam everywhere. When i popped the hood, low and behold, after the body lift i had snapped one of the heater core tubes off. Right now it's holding on with about a 1/4" of tube left sticking out of the firewall. I called up nissan and they said that i have to replace the entire heater core because they do not sell the little plastic hose thing that screw right on. Now, Being a high school student with one hell of a mod bug, I don't want to spend $150 + shipping on a new heater core. I'm looking for the cheapest fix possible. I'm thinking about going down to a wrecking yard and seeing if they can rip the heater core out for me (or do it myself) and just buy the nozzle.
Unless anyone else has a better plan or knowledge of somewhere else i can get a heater core tube?
Edit: Can i just disconnect the inlet and outlet hoses and join them together temporarily so i dont have another spill? at least until i get a new core?
2002 5 speed 4x4 SAS'ed.
Daww look at her
Have YOU cut into your truck today?
SAS stands for Super Awesome Stuff. (not really)
DIY OBA
DIY snorkel
DIY Paint Can Air box
Build Thread
zachbiz is offline
post #2 of 26 Old 08-14-2010, 02:50 PM
Fzzt
Moderator
Fzzt's Avatar
Quoted: 20 Post(s)
2009 OR Xterra
Fzzt has a spectacular aura about them Fzzt has a spectacular aura about them
I don't know why you couldn't just join them together for the time being.
Junkyard sounds like a plan. Good luck.
Traded in all my project cars for a new Xterra, not an ounce of buyers remorse. My build thread
Fzzt is offline
2009 OR Xterra
post #3 of 26 Old 08-14-2010, 03:31 PM
Bklyn.X
Brooklyn br0
Bklyn.X's Avatar
Quoted: 52 Post(s)
Bklyn.X has a spectacular aura about them Bklyn.X has a spectacular aura about them
Garage
We F’d this same thing up on a buddies X during his BL. We did not take it off while lifting.
We just cut the broken tube so it was clean and would not crack more and attached the hose onto the ¼” that was left. It has been holding for more than a year. Do you have enough to grab and hold the hose?
Tom (a hostile voice of a previous generation) & Bklyn.X
Never use aftermarket if the factory has what you need.
Bklyn.X is offline
post #4 of 26 Old 08-14-2010, 11:39 PM
vandebogart
vandebogart's Avatar
Quoted: 3 Post(s)
vandebogart is a jewel in the rough vandebogart is a jewel in the rough vandebogart is a jewel in the rough
Yea you can connect the tubes, you just won't have A/C. Thats what I did when mine broke. I went to Lowes and bought some copper connectors. I mixed and matched em and ended up with a piece that would fit in the broken tube and the inlet tube. The end that went into the firewall had threads that bit into the plastic some. I've had it in since september of last year and its been worked fine. I bought a used heater core from some one that was parting out a wrecked X... just haven't had the time to replace it
--Shaun
'02 Xterra XE 5spd 4x4
-Lots of mods
vandebogart is offline
post #5 of 26 Old 09-29-2010, 03:40 PM
Snow Chaser
Snow Chaser's Avatar
Snow Chaser is a jewel in the rough Snow Chaser is a jewel in the rough Snow Chaser is a jewel in the rough
Hey Zach what did you end up doing for this?
I did the same thing yesterday...
-Dylan-
Mineral Blue 2001 SE 4x4. October 2010 Ronin Wheelers TOTM
http://www.clubxterra.org/forums/showthread.php?t=19760
Snow Chaser is offline
post #6 of 26 Old 09-29-2010, 04:23 PM
miskywhisky
Quoted: 29 Post(s)
Maybe a mod here can go to the how to thread and bold and jack up the font about this.
Snow chaser, not much you can short of yanking it, the tube is not a separate part and the way to get to it means ripping your dash out. Mines been leaking slowly for months and i just live with it. I did put a better clamp on the hose and that helped the most.
miskywhisky is offline
post #7 of 26 Old 09-29-2010, 04:36 PM Thread Starter
zachbiz
zachbiz's Avatar
i was thinking about getting a replacement off ebay (they run about $50) or taking a large threaded brass nipple and threading it into the tube. its a hame nissan doesnt sell the tubes separately.
Daww look at her
DIY OBA
DIY snorkel
Build Thread
zachbiz is offline
post #8 of 26 Old 09-29-2010, 05:46 PM
Steeze
2009 Xterra of the year
Steeze's Avatar
Quoted: 2 Post(s)
2005 Xterra
Steeze has a spectacular aura about them Steeze has a spectacular aura about them
The same thing happened to me... I posted info on this in the BL thread years ago.. read through the threads carefully... it could've been avoided
Steeze is offline
2005 Xterra
post #9 of 26 Old 09-29-2010, 05:55 PM
J Everett
J Everett's Avatar
2008 Xterra
J Everett is a jewel in the rough J Everett is a jewel in the rough J Everett is a jewel in the rough
We almost did the same thing to RATTFINK's rig when we did the BL. We ended up disconnecting the bracket that held the hoses from the firewall; that gave it enough flexibility to allow the lift.
**Always have someone watching under the hood for parts that look stressed when you are jacking the body up off the frame!
In the meantime, yes, you can simply connect the hoses to each other and refill the cooling system with coolant. You just won't have any heat in the cab.
--Jason
My 2008 Super Black SE "The Elephant"
The ass of my ride will swap ends faster than the OP will fail an English class.
J Everett is offline
2008 Xterra
post #10 of 26 Old 09-29-2010, 06:17 PM
Bennyboy42
Bennyboy42's Avatar
Bennyboy42 is on a distinguished road
i did the same thing. just connect them, but you won't have heat.
--Ben
2001 4X4 Xterra SE Solar Yellow
PML, 2" BL, MT's, Gibson Catback, Full Skids and a whole lot of herculiner and black paint!
http://www.clubxterra.org/forums/showthread.php?t=12568
Bennyboy42 is offline
