xterra engine codes - Nissan Xterra Forum
post #1 of 92 Old 08-23-2007, 10:31 AM Thread Starter
Ricer-X
WHO DAT
Ricer-X's Avatar
Ricer-X has much to be proud of Ricer-X has much to be proud of Ricer-X has much to be proud of Ricer-X has much to be proud of Ricer-X has much to be proud of Ricer-X has much to be proud of Ricer-X has much to be proud of Ricer-X has much to be proud of
xterra engine codes
these are for the 3.3l
FRONTIER & XTERRA 3.3L
P0000
No Self Diagnostic Failure Indicated
P0100
MAF Sensor
P0105
Absolute Pressure Sensor
P0110
IAT Sensor
P0115
ECT Sensor
P0120
TP Sensor
P0125
ECT Sensor
P0130–P0134
Front HO2S RH Bank
P0135
Front HO2S Heater RH Bank
P0136–P0140
Rear HO2S RH Bank
P0141
Rear HO2S Heater RH Bank
P0150–P0154
Front HO2S LH Bank
P0155
Front HO2S Heater LH Bank
P0157–P0161
Rear HO2S LH Bank
P0171
Fuel Injection System Lean RH Bank
P0172
Fuel Injection System Rich RH Bank
P0174
Fuel Injection System Lean LH Bank
P0175
Fuel Injection System Rich LH Bank
P0180
Tank Fuel Temperature Sensor
P0217
Engine Over Temp
P0300
Multiple Cylinder Misfire
P0301–P0306
Misfire Cylinders 1–6
P0325
Knock Sensor
P0335
CKP Sensor
P0340
CMP Sensor
P0400
EGR Function
P0402
EGRC-BPT Valve Function
P0420
TWC Function
P0430
TWC Function
P0440
EVAP System Small Leak
P0443
EVAP Canister Purge Control Valve & Solenoid Valve
P0446
EVAP Canister Vent Control
P0450
EVAP System Pressure Sensor
P0500
VSS
P0505
IAC-AAC Valve
P0510
CTP Switch
P0600
A/T Control & Communication Line
P0705
Park Neutral Position Switch/Circuit
P0710
ATF Temp Sensor/Circuit
P0720
Vehicle Speed Sensor/Circuit
P0725
Engine Speed Signal
P0731
A/T 1ST Gear Function
P0732
A/T 2ND Gear Function
P0733
A/T 3RD Gear Function
P0734
A/T 4TH Gear Function
P0740
TCC Solenoid/Circuit
P0744
A/T TCC Switch/Valve Function
P0745
Low Pressure Solenoid/Circuit
P0750
Shift Solenoid A/Circuit
P0755
Shift Solenoid B/Circuit
P1105
MAP/BARO Switch Solenoid Valve
P1148
Closed Loop B1
P1168
Closed Loop B2
P1320
Ignition Signal
P1336
CKP Sensor
P1400
EGR Valve & EVAP Canister Purge Control Solenoid Valve
P1401
EGR Temperature Sensor
P1402
EGR System
P1440
P1444
Purge Volume Control Valve
P1446
EVAP Canister Vent Control Valve
P1447
EVAP System Purge Flow Monitoring
P1448
Vacuum Cut Valve
P1490
Vacuum Cut Valve Bypass Valve
P1491
P1605
A/T Diagnosis Communication Line
P1705
Throttle Position Sensor/Circuit A/T
P1706
PNP Switch/Circuit
P1760
Over/Run Clutch Solenoid/Circuit
additional resources courtesy of NateDawgG
http://www.obd-codes.com/trouble_codes/
Dustin - 2004 XE V6 2wd; 3" SL, 2" BL, 33x12.5" ATs, HooHaa Steering, Idler arm Brace, 5% tint, Bilstein HD shocks, SAW Tbars, 1/2" ball joint spacers, piaa, HD Tbar anchors, B&M Tranny Cooler Stock Intake Mod, blacked out plastics/wheels/rack
Ricer-X is offline
post #2 of 92 Old 08-23-2007, 10:33 AM
Anthony
ClubX Administratorator
Anthony's Avatar
Anthony is a glorious beacon of light Anthony is a glorious beacon of light Anthony is a glorious beacon of light Anthony is a glorious beacon of light Anthony is a glorious beacon of light
Nice Post. I stickied it for ya.
04 XE 4x4 Black 5spd - (The Wheeler)
04 XE 4x4 Blue (The Wife's)
02 SE 4x4 Green (The Work truck) - SOLD and gone
My Xterra Pics Page
Anthony is offline
post #3 of 92 Old 08-23-2007, 04:14 PM Thread Starter
Ricer-X
WHO DAT
Ricer-X's Avatar
ILL GET THE KA24 ONES TOMORROW AND ADD THEM TO MY POST ABOVE
appreciate the sticky anthony
Ricer-X is offline
post #4 of 92 Old 08-23-2007, 04:19 PM Thread Starter
Ricer-X
WHO DAT
Ricer-X's Avatar
FRONTIER & XTERRA 2.4L
P0000
P0100
MAF Sensor
P0105
P0110
IAT Sensor
P0115
ECT Sensor
P0120
TP Sensor
P0125
ECT Sensor
P0130P0134
Front HO2S
P0135
Front HO2S Heater
P0137P0140
Rear HO2S
P0141
Rear HO2S Heater
P0171
P0172
P0180
P0300
P0301P0304
Misfire, Cylinders 14
P0325
Knock Sensor
P0335
CKP Sensor
P0340
CMP Sensor, Detectable & Non-Detectable Circuit
P0400
EGR Function
P0402
EGRC-BPT Valve
P0420
TWC Function
P0440
P0443
EVAP Canister Purge Volume Control Solenoid Valve
P0446
EVAP Canister Vent Control Valve Circuit
P0450
EVAP Control System Pressure Sensor
P0500
VSS
P0505
IAC-AAC Valve
P0510
CTP
P0605
ECM/ECCS Module
P1105
P1148
Closed Loop Control
P1320
Ignition Signal
P1336
CKP
P1400
EGR & Canister Control Solenoid Valve
P1401
P1402
EGR System
P1440
P1444
P1446
Vacuum Cut Valve
P1447
EVAP Purge Flow Monitor
P1448
Vacuum Cut Valve
P1490
Vacuum Cut/Bypass Valve
P1491
P1706
Park/Neutral Position Switch
P1775
TCC Solenoid Valve Circuit
P1776
TCC Clutch Solenoid Valve
Ricer-X is offline
post #5 of 92 Old 06-09-2008, 07:53 PM
terry345
terry345 is on a distinguished road
how about the flash codes.
P0301 = 0608 on light flash when activating pcm with key on and turn screw clockwise 2 seconds then back.
Does anyone have all of the flash codes?
terry345 is offline
post #6 of 92 Old 06-09-2008, 08:36 PM
json3904
ADMIN
json3904's Avatar
Quoted: 1 Post(s)
json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of
terry345 what do you mean "flash codes"?????
**New site rules and guidelines** Click Here
json3904 is offline
post #7 of 92 Old 06-10-2008, 02:16 PM
terry345
The flash codes are obtained when you turn you key on, then you use a small screwdriver to turn the mode selector on the PCM to cw and leave for 2 seconds, then ccw back to normal position.
The check engine light will flash the codes, for example, 6 slow flashes followed by 8 fast flashes = 0608 which converts to P0301.
My Haynes manual only lists the flash codes and their P conversion on faults that will turn on the check engine light.
Now the flash codes are not exact as I found out today when visiting my Auto Zone store.
They found P0325 and P1336.
P1336 Crankshaft position sensor is about $12.00
P0325 Knock Sensor is over $ 100.00 and harder to get to.
It's under the Intake Manifold.
The Crankshaft position sensor is not too hard to get to on this small V-6.
Can either of these sensor faults cause the engine to lope?
Thanks,
terry345 is offline
post #8 of 92 Old 06-10-2008, 02:31 PM Thread Starter
Ricer-X
WHO DAT
Ricer-X's Avatar
if your xterra isnt supercharged then the knock sensor is not somehting you need to worry about, if you replace it you will have the same code a few months later
90% of us 1st gen N/A v6 guys have it, ive had that code for about 2yrs now
Ricer-X is offline
post #9 of 92 Old 06-10-2008, 03:20 PM
json3904
ADMIN
json3904's Avatar
Quoted: 1 Post(s)
i as well have the Knock sensor, and as to the Crankshaft position sensor that might be the reason but im not sure....
json3904 is offline
post #10 of 92 Old 06-16-2008, 08:31 PM
coloradox
coloradox's Avatar
coloradox is on a distinguished road
well i have acode po 430 catalyst below threshold bank 2 is that a o 2 sens or a cat
coloradox is offline
