Service Engine Soon light flashing - Nissan Xterra Forum
post #1 of 11 Old 06-16-2010, 09:48 AM Thread Starter
drewha28
2005 Xterra
drewha28 is on a distinguished road
I was driving my 2005 Xterra SE this Tuesday, when suddenly the Service Engine light started flashing fast and the engine started to sputter in rythm. It did this several time. The 4WD light would come on sometimes, and the VDC light was on always. I would still have power, but couldn't accelerate. I would shut the engine off and wait several minutes. I would then start the engine and the problem would be gone. This would last for several minutes before it would do it all over again. I've read it might be the MAF sensor or the ITA sensor, or both. Any suggestions? Because this happens so randomly, I can't catch it to get a diagnostic...
drewha28 is offline
2005 Xterra
post #2 of 11 Old 06-16-2010, 11:48 AM
granitex
granitex has a spectacular aura about them granitex has a spectacular aura about them
blinking SES, is a big deal and you could cook a cat in a big hurry. The code should still be stored.
2004 XE Shrockworks front with winch, ARB Lockers front and rear, Calmimi steering, Sliders, 3inch SL, custom rear bumper w/tire carrier, bumper lights, custom roof rack, CB, Laptop mount, Sgt lobo, missing rear swaybar, Quest Alt, diff drop, Aux e-fan, Fuse block, tranny filter and cooler, axle truss and skid, Nismo cat back,Mile Marker hubs, Thorleys, 33's .
granitex is offline
post #3 of 11 Old 06-16-2010, 12:52 PM
echo_nine
echo_nine's Avatar
2003 Xterra
echo_nine will become famous soon enough
don't drive it. My dad just blew a piston in a 2005 f250 because he drove with the flashing check engine light. He had the loss of power issue and wierd sounds then the piston snapped and he had to buy a new motor. When it flashes you should park it were ever your at and get it towed to a shop you trust.
echo_nine is offline
2003 Xterra
post #4 of 11 Old 06-16-2010, 01:38 PM Thread Starter
drewha28
2005 Xterra
I'm no longer driving it. I'm trying to figure out what's causing the problem and how to go about fixing it. I have a shop I trust. Do you think there is a code he can see if he runs a diagnostic?
drewha28 is offline
2005 Xterra
post #5 of 11 Old 06-16-2010, 06:50 PM
TheMonocle
TheMonocle's Avatar
2004 SC/SE Xterra
TheMonocle is on a distinguished road
Had something similar happen to me recently. The service light came on, and the car turned off. I could turn it on if I kept my foot on the gas pedal, and could drive, although very slowly, but was able to get it home. Was worried that I was going to have to send it to the shop and spend a good amount of coin to get it fixed. After some DIY trouble shooting, turned out to be a loose and corroded battery cable. Cleaned it up, tightened it up and it's went right back to working like a champ.
TheMonocle is offline
2004 SC/SE Xterra
post #6 of 11 Old 06-16-2010, 07:15 PM Thread Starter
drewha28
2005 Xterra
I wish it was a battery cable...lol... I had all that looked at before this became a problem. I also bought a new battery. I just spoke to my mechanic (who is excellent) and he told me it's not a sensor, and that my computer has no code because it is not a sensor problem. He said it's a voltage problem with the computers that causes the truck to run, and that it's going to take some individual testing of the computers to find it. He said he can definitely find it, but he can't tell me if it will be quick or fast.
drewha28 is offline
2005 Xterra
post #7 of 11 Old 06-16-2010, 07:17 PM
TheMonocle
TheMonocle's Avatar
2004 SC/SE Xterra
if you had a choice, would you prefer quick or fast?
2004 SC/SE Xterra
post #8 of 11 Old 10-16-2010, 04:14 PM
mr greives
2006 Xterra
mr greives is on a distinguished road
im having this same issue with my 06 xterra. check engine starts to flash in rythum with the sputtering of the motor. sounds like its not firing all cylinders and the exhaust smells funny. What did your mechanic finnaly have to do to fix the problem. not too costly i hope.
mr greives is offline
2006 Xterra
post #9 of 11 Old 10-17-2010, 10:33 AM
zachbiz
zachbiz's Avatar
zachbiz will become famous soon enough zachbiz will become famous soon enough
this happened to me a month ago but it was blinking sporadically and looked like it was having a seizure. turns out it was just a snapped fuel evap line.
2002 5 speed 4x4 SAS'ed.
Daww look at her
Have YOU cut into your truck today?
SAS stands for Super Awesome Stuff. (not really)
DIY OBA
DIY snorkel
DIY Paint Can Air box
Build Thread
zachbiz is offline
post #10 of 11 Old 10-18-2010, 11:56 AM
mr greives
2006 Xterra
thanks . ill check to see if thats it. this is one weird problem.
2006 Xterra
