resetting abs light - Nissan Xterra Forum
post #1 of 34 Old 05-02-2007, 04:28 AM Thread Starter
dwarford
resetting abs light
I have a 2003 , model and had main leaf spring break , when this happend it severed the wire for abs going into sensor on wheel . i repaired the wire but abs light stays on . Anybody know how to reset this ? Thanks D..
dwarford is offline
post #2 of 34 Old 05-02-2007, 08:22 AM
ggunn
ggunn's Avatar
My light came on too when I pulled a trailer with a sportbike from Florida to Alabama for about 450 miles. But as soon as I dropped the trailer cut the X off and started it again the light went off.
2000 SE 2wd
ggunn is offline
post #3 of 34 Old 05-02-2007, 08:33 AM
TJTJ
TJTJ's Avatar
Quoted: 192 Post(s)
Talking
IIRC, it resets itself after a number of cycles....you might merely need to wait.
If a week goes by, and the light stays on, either you DID NOT repair the wire as you thought (The splice changed the resistance, etc...), or something else might also be out of whack.
If you nail the brakes, does the X skid, or does the ABS pulse/seem to work?
If the connection is bad or its not reset, it should skid.
If it pulses/seems to work, but the light stays on, then it might be part of the send loop instead, etc.
-TJ
TJTJ is offline
post #4 of 34 Old 05-04-2007, 04:58 PM
WoodyTX
Seasoned
You might also want to unplug the battery for about 5 minutes. Of course, you have to reset your radio stations, but...
WoodyTX is offline
post #5 of 34 Old 07-03-2008, 07:22 AM
unclehardrock
prop jock
unclehardrock's Avatar
05 & 08 S Xterra
reviving an old thread....gotta love the search tool
anyone know if this is also true for a 2nd gen? my abs light is currently on- do i just need to wait for it to go off, can it be cleared with the scanguage? thanks for the info
ps- it's on due to the lift/wheels/tires that are finally on my x....i'm picking it up tonight and will have pics up as soon as i get it back in my possesion
-john
-John
"real planes have props"
Too many mods to list.....see the build thread below
unclehardrock's x
unclehardrock is offline
05 & 08 S Xterra
post #6 of 34 Old 07-03-2008, 12:44 PM
k1w1t1m
Kiwi Bloke
k1w1t1m's Avatar
I know on the 1st gens there is a routine for reading lamp flashes and reseting the ABS. However I have just gone through the whole chapter for the 2nd gen and all I can find is information relating to the use of Consult II. All I can suggest disconnecting the battery and depressing the brake pedal before reconnecting the battery.
k1w1t1m is offline
post #7 of 34 Old 07-05-2008, 04:29 PM
unclehardrock
prop jock
05 & 08 S Xterra
okay, so i found this on some other nissan sites on the web? i'm willing to give it a shot to save me from making a trip to the dealer to get the abs/slip lights to go away.....my question is, does anyone know how to ground the /#9 pin on the data link connector properly? i can't find an answer for it anywhere and i don't want to mess even more crap up on the truck. also, anyone know why the scanguage doesn't pick up any of these codes on the x? i thought it was supposed to be able to read them, and their website says it has full compatability with the x?
-john
After tooling around in few Nissan sites.... I realized there is absolutely nothing on this subject. So I asked a Nissan tech and this is what he sent to me. Hope this helps someone.
ABS LIGHT RESET/DIAGNOSTIC PROCEDURE
When a problem occurs in the ABS, the warning lamp on the instrument panel comes on. To start the selfdiagnostic
results mode, ground the self-diagnostic (check) terminal located on Data Link Connector. The
location of the malfunction is indicated by the warning lamp flashing.
SELF-DIAGNOSIS PROCEDURE
1. Drive vehicle over 30 km/h (19 MPH) for at least one minute.
2. Turn ignition switch OFF.
3. Ground terminal 9 of Data Link Connector with a suitable harness.
4. Turn ignition switch ON while grounding terminal 9.
Do not depress brake pedal.
5. After 3.0 seconds, the warning lamp starts flashing to indicate
the malfunction code No. (See NOTE.)
6. Verify the location of the malfunction with the malfunction code
chart. Then make the necessary repairs following the diagnostic procedures.
7. After the malfunctions are repaired, erase the malfunction codes
stored in the control unit. See Below
8. Rerun the self-diagnostic results mode to verify that the malfunction
codes have been erased.
9. Disconnect the check terminal from the ground. The self-diagnostic
results mode is now complete.
10. Check warning lamp for deactivation after driving vehicle over 30
11. After making certain that warning lamp does not come on, test
the ABS in a safe area to verify that it functions properly.
NOTE:
The indication terminates after 5 minutes.
However, when the ignition switch is turned from OFF to ON, the
indication starts flashing again.
HOW TO READ SELF-DIAGNOSTIC RESULTS (MALFUNCTION CODES)
1. Determine the code No. by counting the number of times the warning lamp flashes on and off.
2. When several malfunctions occur at one time, up to three code numbers can be stored; the latest malfunction
will be indicated first.
3. The indication begins with the start code 12. After that a maximum of three code numbers appear in the
order of the latest one first. The indication then returns to the start code 12 to repeat (the indication will
stay on for five minutes at most).
HOW TO ERASE SELF-DIAGNOSTIC RESULTS (MALFUNCTION CODES)
1. Disconnect the check terminal from ground (ABS warning lamp
will stay lit).
2. Within 12.5 seconds, ground the check terminal three times.
Each terminal ground must last more than 1 second. The ABS
warning lamp goes out after the erase operation has been completed.
3. Perform self-diagnosis again. Only the start code should appear, no
malfunction codes.
ABS CODES
Code No. Malfunctioning Part Reference Page
12 Self-diagnosis could not detect any malfunctions.
45 Actuator front left outlet solenoid valve
46 Actuator front left inlet solenoid valve
41 Actuator front right outlet solenoid valve
42 Actuator front right inlet solenoid valve
51 Actuator rear right outlet solenoid valve
52 Actuator rear right inlet solenoid valve
55 Actuator rear left outlet solenoid valve
56 Actuator rear left inlet solenoid valve
25 *1 Front left sensor (open-circuit)
26 *1 Front left sensor (short-circuit)
21 *1 Front right sensor (open-circuit)
22 *1 Front right sensor (short-circuit)
31 *1 Rear right sensor (open-circuit)
32 *1 Rear right sensor (short-circuit)
35 *1 Rear left sensor (open-circuit)
36 *1 Rear left sensor (short-circuit)
18 *1 Sensor rotor
61 *3 Actuator motor or motor relay
63 Solenoid valve relay
57 *2 Power supply (Low voltage)
71 Control unit
-John
unclehardrock's x
05 & 08 S Xterra
post #8 of 34 Old 07-05-2008, 06:26 PM
k1w1t1m
Kiwi Bloke
k1w1t1m's Avatar
Good luck. Let us know if it works or not. That looks like the instructions for the 1st gens.
k1w1t1m is offline
post #9 of 34 Old 07-05-2008, 09:48 PM
json3904
ADMIN
json3904's Avatar
Quoted: 1 Post(s)
the reason the scanguage dont pick up those codes is they have nothing to do with the cel... it is on another system if you know what i mean....
**New site rules and guidelines** Click Here
json3904 is offline
post #10 of 34 Old 07-05-2008, 10:55 PM
k1w1t1m
Kiwi Bloke
k1w1t1m's Avatar
Exactly. They're probably Nissan proprietry codes too.
k1w1t1m is offline
