2002 climate control light not working - Nissan Xterra Forum: Xterra Forums
Old 02-14-2010, 12:39 PM
tiojam tiojam is offline
Member: #11573
tiojam is on a distinguished road
My center controls is hard to see at night because there is no light. Seems like the bulb in AC/ climate controls are out. How do I take off the center plastics and change the bulb inside if there is one. Anyone had done this issue? Is there a thread on this already I apologise. Thanks in advance.
Old 02-14-2010, 12:43 PM
dejablue's Avatar
dejablue dejablue is offline
Moderator
Member: #3797
2002&2003 Xterra
dejablue will become famous soon enoughdejablue will become famous soon enough
there is no bulb you can change, you will have buy a new controller
Dennis
Old 02-14-2010, 12:53 PM
dejablue's Avatar
Moderator
Member: #3797
2002&2003 Xterra
http://www.courtesyparts.com/27135-s...-p-579899.html
Dennis
Old 02-14-2010, 02:24 PM
Member: #11573
Ok thanks. Is there diagrams how to take off plastic covers and panels for center?
Old 02-14-2010, 02:27 PM
Member: #11573
I guess the bulb or LED is enclosed in the plastic. Thanks moderator.
Old 02-15-2010, 04:11 PM
dejablue's Avatar
Moderator
Member: #3797
2002&2003 Xterra
yes there is a couple of people tried to repair, they sell the led at radio shack for 2dl but so far that i know no one has been able to open it up with out destroying it.
Dennis
Old 11-28-2012, 08:25 PM
PsiFire PsiFire is offline
Member: #37643
PsiFire is on a distinguished road
Just to update, you CAN replace the backlight in the climate controls, at least on my 2002 you can. I got 2 incandescent bulbs from http://autolumination.com/74.htm. They are neo-wedge bulbs and come in various colors. I got the blue to try and stick to the same color as the bulbs that I was replacing. The downside is the replacement bulbs are shorter in the shaft than the bulbs being replaced. I am about to buy another set in the LED style to see if I can improve the brightness (right now it's quite dim). But it's better than dark.
