need to replace distributor - Nissan Xterra Forum
post #1 of 12 Old 02-12-2010, 07:34 PM Thread Starter
teamgreaves
2003 Xterra
teamgreaves is on a distinguished road
so I have this ticking sound when ever i start my truck or when i get out of the throtle. i found that the noise is coming from the distributor. it's also throwing the knock sensor which is not allowing the truck to pass smog. i bought the new distributor but i'm trying to figure out how to install it or better yet set the timing if anyone can help please repond. thanks! Teamgreaves
teamgreaves is offline
2003 Xterra
post #2 of 12 Old 02-12-2010, 07:56 PM
dejablue
dejablue's Avatar
Quoted: 242 Post(s)
2003 Xterra
dejablue is a glorious beacon of light dejablue is a glorious beacon of light dejablue is a glorious beacon of light dejablue is a glorious beacon of light dejablue is a glorious beacon of light
mark the location of the rotor on the old dist, transfer the mark to the new dist ,pull the old out put the new in with rotor pointing to new mark will get you close so you can start the truck ,finish with a timing light.
Dennis
dejablue is offline
2003 Xterra
post #3 of 12 Old 02-12-2010, 08:21 PM Thread Starter
teamgreaves
2003 Xterra
which mark on the pulley do i set the timing to?
2003 Xterra
post #4 of 12 Old 02-12-2010, 08:32 PM
dejablue
dejablue's Avatar
Quoted: 242 Post(s)
2003 Xterra
8 to 12 btdc each mark on the balancer is 5 deg clockwise.
Dennis
dejablue is offline
2003 Xterra
post #5 of 12 Old 02-12-2010, 08:40 PM Thread Starter
teamgreaves
2003 Xterra
when cranking the motor to set the dis to number one do i turn clockwise or counter clockwise.
2003 Xterra
post #6 of 12 Old 02-12-2010, 09:10 PM
dejablue
dejablue's Avatar
Quoted: 242 Post(s)
2003 Xterra
clockwise standing in front of motor
Dennis
dejablue is offline
2003 Xterra
post #7 of 12 Old 02-13-2010, 08:17 AM
soccerbrace
blah blah blah
soccerbrace's Avatar
Quoted: 1 Post(s)
soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold
rep points for dejablue.
Photobucket
soccerbrace is offline
post #8 of 12 Old 02-13-2010, 09:56 AM
baf6
Spaz
baf6's Avatar
baf6 Totally Rocks baf6 Totally Rocks baf6 Totally Rocks baf6 Totally Rocks
rep'd
baf6 is offline
post #9 of 12 Old 02-13-2010, 01:57 PM
dejablue
dejablue's Avatar
Quoted: 242 Post(s)
2003 Xterra
cool
Dennis
dejablue is offline
2003 Xterra
post #10 of 12 Old 02-26-2010, 05:04 PM
thumperpaul
2003 Xterra
thumperpaul is on a distinguished road
My '03 does the exact same thing at startup, I think it is a common malady with the 3.3L..
thumperpaul is offline
2003 Xterra
