How much to re-pack front wheel bearings - Nissan Xterra Forum: Xterra Forums
Old 02-12-2010, 04:27 PM
Nerfball6 Nerfball6 is offline
Member: #11460
Nerfball6 is on a distinguished road
Hi all,
I have a question ... How much do you think a reputable repair shop would charge to repack the front wheel bearings on both sides. Including a new seal?
Thanks!!
My 2002 SE, S/C: http://www.shadowlandstudios.com/ima...02.11.2010.jpg
Old 02-12-2010, 04:34 PM
miskywhisky miskywhisky is offline
Member: #9010
miskywhisky will become famous soon enoughmiskywhisky will become famous soon enough
don't know but if you got some tools its not that bad
http://www.rkrenn.com/xterra/howto/bearing/bearing.htm
Old 02-12-2010, 06:07 PM
struggle's Avatar
struggle struggle is offline
Seasoned
Member: #4945
struggle is on a distinguished road
If one is going through all the labor of repacking wouldn't it be better to just replace them while in there?
If its a 4x4 then more labor right?
Just asking.
Old 02-12-2010, 06:51 PM
dejablue's Avatar
dejablue dejablue is offline
Moderator
Member: #3797
2002&2003 Xterra
dejablue will become famous soon enoughdejablue will become famous soon enough
do it your self !
Dennis
Old 02-12-2010, 10:02 PM
granitex granitex is offline
Member: #7326
granitex has a spectacular aura about themgranitex has a spectacular aura about them
There is no reason to replace the bearings as long as they are ok, just repack and call it all good. I do mine several times a year just because I tend to spend a lot of time in water over the hubs. With the right tools it takes longer to clean up after the job than it takes to do them.
2004 XE Shrockworks front with winch, ARB Lockers front and rear, Calmimi steering, Sliders, 3inch SL, custom rear bumper w/tire carrier, bumper lights, custom roof rack, CB, Laptop mount, Sgt lobo, missing rear swaybar, Quest Alt, diff drop, Aux e-fan, Fuse block, tranny filter and cooler, axle truss and skid, Nismo cat back,Mile Marker hubs, Thorleys, 33's .
Old 02-13-2010, 04:20 AM
Member: #11460
Some good information and advice. I appreciate that link and may try this myself next time. I don't have much for tools or a place to work on my X right now, (especially when snow is on the ground) but hopefully that will be changing in the near future.
Anyway, here's why I'm asking. I took my X into a place because of a slow leak on my Pass side front tire, it turned out the wheel was very corroded inside and the seal was bad, so I had them remove all the tires and clean the wheels and re-seal them. While the tires were off they did an inspection and said the wheel bearings needed to be repacked. I decided to trust them and said go ahead since I was already in and they had the wheels off.
Well, they charged me $313.00 for the repacking and to replace the seals. Afterwards I started to wonder if I had been taken so I decided to ask here and do some research on line. I believe now I was. And it pisses me off, though it's after the fact and I can only use it as a learning experience.
I should have waited and researched first. Especially since I've found this forum and the wealth of information and help here.
Old 02-13-2010, 04:30 AM
HIHOOKBRIG's Avatar
HIHOOKBRIG HIHOOKBRIG is offline
Member: #5519
2003 Xterra
HIHOOKBRIG is on a distinguished road
My dealership only charges 140.00. Some repair shops are worse then dealerships now with their prices. For those of us that don't have the facility or tools to do it ourselves, you have to shop around and compare prices for the same job. So far my dealership has been cheaper then the auto repair shop that I was using.
  #8
Old 02-13-2010, 06:38 AM
outwiththeold's Avatar
outwiththeold outwiththeold is offline
Member: #4028
00 Xe 4x4 Xterra
Next time just, ask is anyone nearby that is willing to lend a hand,I work a lot of crazy hours,but will lend you a hand,plus have the tools to get the job done .
warn manual hubs,PML, and a ditched rear sway bar.K&N Drop w/ resonators removed.Plastics Repainted Black.
  #9
Old 02-13-2010, 06:46 AM
Member: #11460
Hey, I really appreciate that!!! One thing I've noticed about this forum is that there are a lot of good people willing to help others out. That's awesome!
  #10
Old 09-23-2010, 08:44 AM
krovikan21's Avatar
krovikan21 krovikan21 is offline
Member: #11837
04 SE N/A Xterra
krovikan21 is on a distinguished road
i am going to attempt to break my wheel packing virginity...feel bad for the x tho i have never done it in 2.5 year SORRY!!!! Well the advance auto 40% off thing right now really saved me a ton getting all the parts i need to do it!
