Signs of a bad distributor? Help! - Nissan Xterra Forum
post #1 of 17 Old 01-27-2010, 08:40 PM Thread Starter
birdmct
birdmct is on a distinguished road
I have a 2000 Xterra 118,000 miles (190,000kms). About a week ago, it stalled in a parking lot after starting. After a couple of times doing this, I took it in and mechanic is stumped by lack of codes. Only a knock sensor. There is no check engine light. Got the car back for a week with nothing unusual happening. Feeling optomistic it was just bad gas or something, stalled again. Today is bad and now in the driveway, can't get it started anymore. It deteriorated very quickly today. It will fire, run really roughly then die. On subsequent starts, it won't catch. In the last few days, I have noticed that the rpms after start initially go to about 1800 then drop to 1500 then 1000 then to 800 after a few seconds. Today, it just drops below 800 immediately then dies. At one point, when trying to hold a steady idle, the rpms fluctuated about 200 rpms before stabilizing. Now, it won't start at all in the driveway. I have read a lot of threads and internet stuff and there is talk of cam sensors, MAF sensors, fuel pumps, etc. What does a distributor failure look like. Should that be place number one to start since there are no codes?
Thanks
Andrew
birdmct is offline
post #2 of 17 Old 01-27-2010, 11:02 PM
Silver Dude
Silver Dude's Avatar
Silver Dude will become famous soon enough Silver Dude will become famous soon enough
The distributors bearing goes out. Remove the cap, remove the rotor, remove the tone ring and sensor, remove the rest of the internal guts and covers. Then at the bottom you should find a sealed roller bearing. This bearing should be in good condition. If you see that it has play or has chunks of black stuff at the bottom its definitely bad. Though some people have also had issues with the electronics end of it inspecting the bearing is a good start.
Silver Dude is offline
post #3 of 17 Old 01-28-2010, 07:37 AM
soccerbrace
blah blah blah
soccerbrace's Avatar
Quoted: 1 Post(s)
soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold
Couldn't he just pull the distributor out and check the shaft for play?
To me, it sounds like a MAF problem, or a massive vacuum leak.
This vacuum leak usually is more apparent on the uphills.
Does it sound different?
Try starting your Xterra, pulling the MAF plug, turn the truck off, turn the key to the ON position, plug your MAF back in, start.
Photobucket
soccerbrace is offline
post #4 of 17 Old 01-28-2010, 09:44 AM Thread Starter
birdmct
I tried the MAP suggestion and this is what happened - The car started fine this morning but idled a little high in my opinion. But it started normally. I yanked the MAF and the truck died instantly. I turned the car off then back on, plugged in the MAF and the start did it's usual rough idle and quit. Is this indicitive of a MAF problem?
birdmct is offline
post #5 of 17 Old 01-28-2010, 11:40 AM
soccerbrace
blah blah blah
Quoted: 1 Post(s)
Nope, sounds more like the distributor taking a dump or a fuel problem.
Photobucket
post #6 of 17 Old 01-28-2010, 01:03 PM Thread Starter
birdmct
Thanks for the help so far. The only thing I don't get is that is only a starting problem. Once the car starts, it's fine. It doesn't stall at lights, etc and it has never left me at the side of the road. It's only when the car is turned off and then a re-start is attempted that it acts up. Usually leaving it for a while does the trick to get it started and then it goes fine until the next time it's turned off. A distributor won't do that, will it?
birdmct is offline
post #7 of 17 Old 01-28-2010, 02:19 PM
soccerbrace
blah blah blah
Quoted: 1 Post(s)
Hmmmmm. There are a ton of things that can do that. The simplest one is a dirty air filter.
Photobucket
post #8 of 17 Old 01-28-2010, 02:24 PM
TN4x4Xterra
Moderator
TN4x4Xterra's Avatar
TN4x4Xterra is a jewel in the rough TN4x4Xterra is a jewel in the rough TN4x4Xterra is a jewel in the rough TN4x4Xterra is a jewel in the rough
We have air filters!??!?
TN4x4Xterra is offline
post #9 of 17 Old 01-28-2010, 07:28 PM Thread Starter
birdmct
Took the truck to my mechanic today and since there are no codes except Knock sensor, he's stumped. He thinks the MAF sensor should be ok. He had a look at the dist and it looked ok. He's thinking of replacing the knock sensor tomorrow. It's a 4 hr job and a 250 dollar part. It scares me a little because I havn't seen too many people saying that the knock sensor is a big deal. Would it cause the car to run roughly on a start and work sometimes and not others? Should I call him tomorrow morning and tell him to hold off. I don't want to pay $1000 for something that probably won't be the problem. Any thoughts?
birdmct is offline
post #10 of 17 Old 01-30-2010, 06:55 PM Thread Starter
birdmct
Found the problem. The wiring harness on top of the fuel tank that connects to the fuel pump was badly corroded. The mechanic went through the back seat to the top of the tank and replaced the wiring harness to the pump. He had to make his own instead of replacing the whole pump. Fixed!
birdmct is offline
