Driver side power window!!! - Nissan Xterra Forum: Xterra Forums
Old 01-24-2010, 09:25 AM
coastx coastx is offline
Member: #11270
2006 Xterra
coastx is on a distinguished road
Alright, I have experienced the pain of Xterra windows in the past but this a new one for me. I went to put my window down at work on friday and when I hit the auto down switch it only went 3/4 of the way down. No worries it's 0500 and I thought maybe I just hit the button, until it happened again when I went to put my window down again. When I went to put my window up I got nothing. No motor noise at all. I replaced the swicth because I had a similar problem on my 00 Xterra, but that did not fix it. All of the other windows work, I was able to slide the glass up by hand so I dont think it's off the tracks. Do the windows have independant fuses? I'm trying to rule out everything before I repalce the motor. Thanks in advance for any advice you guys can give me. You always seem to have the answers
Old 01-24-2010, 10:21 AM
dejablue's Avatar
dejablue dejablue is offline
Moderator
Member: #3797
2002&2003 Xterra
dejablue will become famous soon enoughdejablue will become famous soon enough
all on the same fuse . has any water or snow got on the switch ?
Old 01-24-2010, 01:07 PM
Member: #11270
2006 Xterra
I live in NOLA now so it is likely that rain got on the switch. I replaced the switch yesterday. guess my next step is see if the motor is getting power. I will have to wait untill i get to work to do that
Old 01-25-2010, 01:33 PM
rockyxterra rockyxterra is offline
Seasoned
Member: #4102
2005 Xterra
rockyxterra is on a distinguished road
im having the same problem on my 05 the window wouldnt go up and i went to pull the panel off and the window went up by its self so ....i replaced my switch and nothing...
2005 white xterra
Old 01-25-2010, 02:16 PM
soccerbrace's Avatar
soccerbrace soccerbrace is offline
blah blah blah
Member: #1634
soccerbrace is a splendid one to beholdsoccerbrace is a splendid one to beholdsoccerbrace is a splendid one to beholdsoccerbrace is a splendid one to beholdsoccerbrace is a splendid one to beholdsoccerbrace is a splendid one to behold
The switch is a 5 position switch I beleive, as in it has an auto up and an auto down.
To me, it sounds like the regulator, but try a reset before you spring for a new one.
Here is how you reset it:
1. Manually (do not go all the way down to auto), go all the way down.
2. Go all the way UP manually (NOT AUTO!) and hold the switch the whole time. When it is in the fully up position hold the switch for another 4 seconds (count slow). Do not let go of the switch. After 4 seconds, try to go down, and see what happens.
Photobucket
Old 01-25-2010, 04:29 PM
raiderfernie raiderfernie is offline
Seasoned
Member: #4237
raiderfernie is on a distinguished road
sounds like the motor to me.
Old 01-25-2010, 05:48 PM
Member: #11270
2006 Xterra
looks like I'll be springing for the new regulator and motor. I went by NAPA after work and they said it's a dealer part, I think I can order one from Advanced. If anyone has a good place let me know. Thanks for everyones help.
  #8
Old 01-25-2010, 05:56 PM
blah blah blah
Member: #1634
Did you try what I recommended?
Photobucket
  #9
Old 01-25-2010, 06:19 PM
Member: #11270
2006 Xterra
soccerbrace,
I can't get the window to move at all unless I slide it down with my hands, and the motor will not make any noise. Do you think it will be worthwhile to have someone else manipulate the switch while I muscle the window down and back up? I will try just about anything before I drop money on a new motor.
  #10
Old 01-26-2010, 11:32 AM
blah blah blah
Member: #1634
Yeah, I would do that first, Also, I would take the door panel off and have a look see before purchasing anything.
Photobucket
