How to set the TPS....2001 3.3L? - Nissan Xterra Forum
post #1 of 11 Old 01-17-2010, 02:06 PM Thread Starter
THECATMAC
THECATMAC's Avatar
2001 4WD Xterra
I cannot seem to find a thread on this, if the engine has to be warm or what. What is the proper procedure?
"It is what it is"!!!!!
THECATMAC is offline
2001 4WD Xterra
post #2 of 11 Old 01-17-2010, 04:22 PM
Xterra Mike
Silver Submarine
Xterra Mike's Avatar
Quoted: 14 Post(s)
2001 SE Xterra
Garage
as far as i know it has to be set buy the factory. i got a new one and just tried to put it in the same place as the old one was. it seemed to work.
Xterra Mike is offline
2001 SE Xterra
post #3 of 11 Old 01-17-2010, 07:02 PM
Cyclemut
Most Halal Mod
Quoted: 2 Post(s)
02 Xterra
The only reason that the engine has to be warm is so that the wax pellet gets out of the way and the throttle is at it's normally warm running position.
Then you need to get a continuity tester, a feeler gauge and start holding your tongue in the right position.
Find the two prongs on the upper portion of the TPS that have continuity when the throttle is closed and the tps is twisted all the way closed. As you open the throttle, the continuity should stop. Then adjust according to this:
Cyclemut is offline
02 Xterra
post #4 of 11 Old 01-18-2010, 06:38 AM Thread Starter
THECATMAC
THECATMAC's Avatar
2001 4WD Xterra
What is the difference between Base idle speed and target idle speed?
2001 4WD Xterra
post #5 of 11 Old 01-18-2010, 09:27 AM
Cyclemut
Most Halal Mod
Quoted: 2 Post(s)
02 Xterra
Base Idle is with the computer not bumping it with the Idle Air Control Valve. Target idle is what the computer is to maintain.
Up here, at altitude, I just let the engine get warm, then unscrew the base idle adjustment screw until the engine idles higher, then screw it in a bit. This gets the base idle closer to the target idle and helps with cold starts.
Cyclemut is offline
02 Xterra
post #6 of 11 Old 12-15-2010, 03:36 PM
I0Xterra0I
Cyclemut u should make diy for adjusting your base idle.....so are we suppose to just warm it up and then unscrew the base isle screw.....it my tps is right I don't need to mess with it,just the screw?cuz when I warm up and unscrew what I believ to be the base idle screw nothing changes rpm wise?
I0Xterra0I is offline
post #7 of 11 Old 12-15-2010, 05:59 PM
soccerbrace
blah blah blah
soccerbrace's Avatar
Quoted: 1 Post(s)
Is that what you were looking for?
Photobucket
soccerbrace is offline
post #8 of 11 Old 12-15-2010, 06:09 PM
I0Xterra0I
Not really....I'm more worries about where the base idle screw is located and if I need to disconnect he tps before adjusting re base idle screw....can someone give me a pic if the screw on their xterra
post #9 of 11 Old 12-15-2010, 08:24 PM
Cyclemut
Most Halal Mod
Quoted: 2 Post(s)
02 Xterra
Don't bump an old thread with your own problem. This is from a year ago!
Cyclemut is offline
02 Xterra
post #10 of 11 Old 10-26-2011, 05:08 PM
toothpick745
My TPS just went, is this hard to do myself?
Black 2001 xterra w/: infinity kappa front speakers, alpine type-R rear speakers, alpine type-R 12" sub, bassworx box, alpine 500w mono amp with 2 frad cap, Rokford Fosgate 1000w 4ch amp, pioneer DEH-P6000UB deck, Bilstein shocks, Volant CAI.
toothpick745 is offline
