CV joint help - Nissan Xterra Forum
post #1 of 14 Old 12-03-2009, 06:58 PM Thread Starter
Alpha
Alpha's Avatar
Quoted: 1 Post(s)
Alpha is on a distinguished road
CV joint help
Whats up guys?
I broke my CV joint last Saturday, my truck has been parked since.
I already have the CV and planning to get to swapping it out tomorrow.
Problem being I have never done this before so I am kind of lost on how to do it:
If anyone has a write up I would greatly appreciate it.
I am guessing I would have to jack up the truck, put a stand under the diff and the jack under the LCA, disconnect the UCA and steering, take off the auto hub and turn the knuckle as far as possible, unbolt the cv off the diff and wiggle the CV out, put the new one in and reassemble.
Only thing I dont know how it works is the splines into the diff when I replace it and how it assembles onto the wheelbearing.
Any help is appreciated, thanks in advance.
Cheers
My truck is bigger, so I know more than you.
Alpha is offline
post #2 of 14 Old 12-03-2009, 07:25 PM
Bklyn.X
Brooklyn br0
Bklyn.X's Avatar
Quoted: 55 Post(s)
Bklyn.X has a spectacular aura about them Bklyn.X has a spectacular aura about them
Garage
If I remember right this is what we did.
Put the truck up on jack stands and take the wheel off.
You need to take the auto hub off because of the snap ring that holds the axle;
Here are some pictures from the ”servicing front bearings” instructions everyone uses that show the snap ring removal;
Removing the snap ring from the fixed cam assembly.
Working the snap ring with the flathead screwdriver.
Then remove bolts (I think 6) that fix the drive shaft to the final drive on the other side of the axle. Separate the drive shaft from the spindle by tapping the outside end with a hammer and work that crap out. You Might have to take out the shock to give room. Don’t lose the washer and the fixed cam assembly. Grease and then work the new one in, drive shaft fixing bolts (I don't know the torque spec on these bolts, sorry), then the fixed cam assembly, washer, snap ring, auto hub (torque spec is 18-25 ft/lb on the hub bolts). Did I forget anything besides the torque specs on those bolts? Anyone else have those?
Tom + Bklyn.X
"All in all not a bad guy - if looks, brains and personality don't count."
Bklyn.X is offline
post #3 of 14 Old 12-03-2009, 07:58 PM Thread Starter
Alpha
Alpha's Avatar
Quoted: 1 Post(s)
Holy crap, that is awesome, I am forever grateful.
I guess I will need to buy snap ring pliers and a torque wrench.
Seems simpler than I thought, we will see how it works out.
Is the grease regular automotive grease or a specific one?
Thanks
Alpha is offline
post #4 of 14 Old 12-03-2009, 08:08 PM
Bklyn.X
Brooklyn br0
Bklyn.X's Avatar
Quoted: 55 Post(s)
Garage
I use Mobil1 wheel bearing grease.
Tom + Bklyn.X
Bklyn.X is offline
post #5 of 14 Old 12-03-2009, 08:25 PM
Bklyn.X
Brooklyn br0
Bklyn.X's Avatar
Quoted: 55 Post(s)
Garage
Drivers side in ‘08;
Passenger side in ‘09;
Tom + Bklyn.X
Bklyn.X is offline
post #6 of 14 Old 12-03-2009, 08:28 PM Thread Starter
Alpha
Alpha's Avatar
Quoted: 1 Post(s)
You must be a pro at it already.
I am going to have to become acquainted with it if I am going to run 35s
Alpha is offline
post #7 of 14 Old 12-03-2009, 08:49 PM
Bklyn.X
Brooklyn br0
Bklyn.X's Avatar
Quoted: 55 Post(s)
Garage
Note the air tools. I don’t know about running 35's. I run 33's and it’s just about at it’s limit. Breaking that crap on the trail kill’s the day.
Tom + Bklyn.X
Bklyn.X is offline
post #8 of 14 Old 12-03-2009, 09:09 PM Thread Starter
Alpha
Alpha's Avatar
Quoted: 1 Post(s)
Agree to disagree if a cherokee with an ls1 cab run 37s locked with a stock dana 30 I'm sure the bigger diff less power open carrier and smaller tires of the xterra will be ok. but thank you very much for the quick imput.
Alpha is offline
post #9 of 14 Old 12-03-2009, 09:48 PM
Bklyn.X
Brooklyn br0
Bklyn.X's Avatar
Quoted: 55 Post(s)
Garage
Cool.
Tom + Bklyn.X
Bklyn.X is offline
post #10 of 14 Old 02-14-2010, 12:16 PM
TJTJ
TJTJ's Avatar
Quoted: 191 Post(s)
Talking
Old post, but just read it.
The D30 is a live axle with no CV's, so there's actually no comparison of strength relative to the topic of what's more likely to break a CV.
And plenty of people have snapped shafts on D30 turning 33's with open diffs, let alone locked with 37's....etc.
So, you cannot predict the overall nissan's IFS CV survival rate based upon a single example of a Dana live axle's.
I have to do both CV's on mine when I get a chance, so, I can try to remember to write it up.
-TJ
TJTJ is offline
