Flat towing an Xterra - Nissan Xterra Forum
post #1 of 11 Old 11-29-2009, 02:41 PM Thread Starter
tgaton
2003 Xterra
tgaton is on a distinguished road
I have an '03 Xterra 4WD AT and the transfer case has a stick shift with a neutral position. The family motor coach assoc. guide says i can't flat tow it behind a motor home, I have towed several different SUV's in the past which had the stick shift transfer case, without any problems. I also would like to know what was to last year they put the stick shift transfer case in before they changed to the electric switch on it. Any help would be appreciated.
tgaton is offline
2003 Xterra
post #2 of 11 Old 11-29-2009, 04:43 PM
baf6
Spaz
baf6's Avatar
Quoted: 1 Post(s)
baf6 Totally Rocks baf6 Totally Rocks baf6 Totally Rocks baf6 Totally Rocks
i dont see a problem as long as the trans and the transfer case are in neutral and the hubs are disengaged
the transfer case selection went to the electronic selector knob with the introduction of the second gen (05+)
baf6 is offline
post #3 of 11 Old 11-29-2009, 06:26 PM Thread Starter
tgaton
2003 Xterra
Thanks, that is what I thought, however mine has auto. hubs.
tgaton is offline
2003 Xterra
post #4 of 11 Old 11-29-2009, 06:31 PM
baf6
Spaz
baf6's Avatar
Quoted: 1 Post(s)
i only say that because the auto hubs can get stuck engaged
baf6 is offline
post #5 of 11 Old 11-29-2009, 06:42 PM Thread Starter
tgaton
2003 Xterra
Thanks, that is a good point and I may want to put a set of manual lockouts on it.
tgaton is offline
2003 Xterra
post #6 of 11 Old 11-29-2009, 06:48 PM
baf6
Spaz
baf6's Avatar
Quoted: 1 Post(s)
either that or engage 4wd, drive forward a few feet, put it back into 2wd, and drive in reverse until you hear both side unclick
baf6 is offline
post #7 of 11 Old 11-29-2009, 06:57 PM Thread Starter
tgaton
2003 Xterra
Yes I have done that on other brands but I have not had a Nissan 4x4. Thanks, it seems you have been there- done that.
tgaton is offline
2003 Xterra
post #8 of 11 Old 11-29-2009, 09:13 PM
json3904
ADMIN
json3904's Avatar
Quoted: 1 Post(s)
json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of
my grandparents have a jeep grand Cherokee that they used to flat tow behind a RV and he never had a problem out of it... he used the blue ox system...
**New site rules and guidelines** Click Here
json3904 is offline
post #9 of 11 Old 11-29-2009, 09:28 PM
Alex Topousis
Quoted: 1 Post(s)
2003 Xterra
Alex Topousis is on a distinguished road
it is very hard on an auto to flat tow it. the tranny is cooled when the motor is running. although both the cases are in neutral the fluid will still spin the gears. I wouldn't do it personally
Alex Topousis is offline
2003 Xterra
post #10 of 11 Old 11-29-2009, 09:35 PM
baf6
Spaz
baf6's Avatar
Quoted: 1 Post(s)
well the tranny pumps its own fluid through the radiator, correct? so the X will be running at speed, and technically shouldnt it cool itself with the air running through the radiator?
baf6 is offline
