Heater doesn't work right! - Nissan Xterra Forum
post #1 of 12 Old 11-23-2009, 11:10 PM Thread Starter
daregister
2005 Xterra
daregister is on a distinguished road
My heater doesn't warm up correctly. I turn my car on and then turn my heater on. My heater no longer heats up when it should. I will heat up when I'm accelerating but when I'm sitting idle it goes back to just cold air coming out. What do you think it is and what do I do about it. I have a 2005 Xterra v6 4 wheel drive. Help. Thanks
daregister is offline
2005 Xterra
post #2 of 12 Old 11-24-2009, 12:54 AM
KJE300
KJE300's Avatar
2006 OR Xterra
KJE300 is on a distinguished road
This happened to me last year. Check your fluids. Make sure the levels are full. I ended up taking it to my mechanic and he filled up the resovoir and said you're done. I just hung my head and called myself pathetic as he consoled me to my truck. Hope this helps...Kurt
Kurt
U.S. Army 7th ID - '91 - '93
U.S. Army 3rd ACR - '93 - '95
Support Our Troops...Freedom isn't Free
My Ride: http://www.clubxterra.org/forums/showthread.php?t=14864
Facebook: http://www.facebook.com/kurtemerson?ref=profile
KJE300 is offline
2006 OR Xterra
post #3 of 12 Old 11-24-2009, 12:54 AM
KJE300
KJE300's Avatar
2006 OR Xterra
BTW after he did that the heater worked!!
Kurt
KJE300 is offline
2006 OR Xterra
post #4 of 12 Old 12-07-2009, 11:42 AM
parkcity22
2006 Xterra
parkcity22 is on a distinguished road
I have the same problem. The engine warms up when it is idling but only cold air comes out until I start driving then it is good and warm. Guess I'll check my fluids too...
parkcity22 is offline
2006 Xterra
post #5 of 12 Old 12-07-2009, 12:37 PM Thread Starter
daregister
2005 Xterra
This worked! Awesome. I'm glad I didn't go to a mechanic and feel foolish, no offense. Thanks!! My heater works!!
2005 Xterra
post #6 of 12 Old 12-07-2009, 01:00 PM
soccerbrace
blah blah blah
soccerbrace's Avatar
Quoted: 1 Post(s)
soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold
First thing you should check when this happens. Glad you got it working!
On another note, this lady came into work with the complaint that when it is cold outside, and she starts the car first thing in the morning, the heater does not work. Then after the engine warms up, it works. Then if it sits for an hour after driving for an hour, it will be warm. We had to explain to the lady that the heater works off of the engine coolant temp and that is has pretty much been working like that since cars have had heaters.
Photobucket
soccerbrace is offline
post #7 of 12 Old 11-18-2013, 09:29 AM
meb0923
2010 Xterra
meb0923 is on a distinguished road
I bought a 2010 Xterra new in 2010 with 4 miles on it. From December 2012 thru end of January 2013 I would start it to warm it up and the heater/defroster would blow only cold air until I started to drive the vehicle. Would warm up in less than a minute once I started driving it after it had been running idle in the driveway for 30 minutes or more. Was at the shop about 3 times.....they never could figure out what was wrong with it. The fourth time I took it in they had to have a Nissan Engineer come out to look at it! Finally found out that there was air leaking into head gasket from a warped part.......Ended up replacing the engine (under warranty) and the vehicle was under 3 years old!!! Now November 2013 it has started again with the heat doing the same thing intermittently, so far.........I am not happy.....Vehicle less that 4 years old and has less that 40K miles on it.......Should not be having these issues!!
meb0923 is offline
2010 Xterra
post #8 of 12 Old 11-18-2013, 09:34 AM
TJTJ
TJTJ's Avatar
Quoted: 191 Post(s)
Talking
Sounds like you're cursed.
I suppose going back and having the head gasket checked makes sense.
-TJ
TJTJ is offline
post #9 of 12 Old 11-18-2013, 09:40 AM
meb0923
2010 Xterra
Cursed would be the nice way to put it..... It has actually been back in the shop since this past Thursday and they can find nothing wrong.....I picked it up this morning and will just see what happens from here....Going into the winter months now so I'm sure with my luck it will happen again! It has happened twice this month but they were 20 degree mornings......the rest of the days it's only been in the 40's so will just have to take the wait and see approach I guess.
meb0923 is offline
2010 Xterra
post #10 of 12 Old 11-18-2013, 09:42 AM
TJTJ
TJTJ's Avatar
Quoted: 191 Post(s)
Talking
The first time you took it in, for the first warped issue, did they find anything that time before getting an engineer in, or, did they bring in an engineer this time already?
Can I assume they would have noticed if the fluid was low?
-TJ
TJTJ is offline
