Creative fix for patching a power steering line - Nissan Xterra Forum
post #1 of 9 Old 11-18-2009, 05:56 AM Thread Starter
wetzie
wetzie is on a distinguished road
Hello everyone
My sons Xterra has a pin hole leak in the high pressure side of the power steering line. The truck is about 3 hours from my home and I want to get it back to do the repairs. Is there a way to put a clamp over the hole and have it hold for that type of trip?
If I have to do the repair, where is the best place to be sure to get the right part? I understand it is hole unit and costs around $200. Are they hard to replace?
Thank you for your help, heloves this car and this is the first repair in 80K and three years!
Sincerely
wetzie is offline
post #2 of 9 Old 11-18-2009, 07:28 AM
mac11
mac11's Avatar
mac11 will become famous soon enough
I just have a friend with the same problem on a different vehicle. He reported slipping a heater hose and securing with hose clamps would NOT work. Whenever the system was pressurized it blew the setup right off.
And be sure to check out the fine print on any "stop leack" additives. All the ones I see in my cursory search are for seal leaks and say nothing about line leaks.
Wish I could be of more help on a solution, but all I really have is to replace the line where it sits.
*Note: All posts I make on this site are fictional for entertainment purposes only. They are not legal advice, actual events, equipment owned or actual locations. If it bothers you, quit being so fragile.
mac11 is offline
post #3 of 9 Old 11-18-2009, 08:54 AM Thread Starter
wetzie
good advise on the clamps blowing off. The dealer is at $550 for the line replacement and thats before he quotes cleaning the engine and if the pump is damaged. Tough times!!
thanx
wetzie is offline
post #4 of 9 Old 11-18-2009, 12:36 PM
mac11
mac11's Avatar
wow, that's ricockulous.
mac11 is offline
post #5 of 9 Old 11-18-2009, 04:38 PM
punkrockdrummerx
punkrockdrummerx's Avatar
punkrockdrummerx will become famous soon enough
there is a product called "rescue tape" you can find it at truck stops...that should do the trick, its self-sealing silicone tape that can withstand pretty high pressure. That with some brake cleaner to clean the line before you tape it should do the trick and tell him to keep some power steering fluid in his X till he gets home and to stop about every hour to check and make sure the level is still good
-Kyle
2002 Yellow Xterra (always open to offers)
2001 Jeep Wrangler
punkrockdrummerx is offline
post #6 of 9 Old 11-18-2009, 04:58 PM
Swordfish
Swordfish's Avatar
Swordfish is on a distinguished road
Yank the entire line. Crank the wheel from full-stop to full-stop a half dozen times (drain out all the fluid). Bung-up the holes, and drive home old-school.
- Jon
2004 Granite XE 4WD 5-Spd 3 seats: LOBO rack, ScanGauge, Pile-O-Tools, 3" SL, 2" BL, Shrock Rear, Bilsteins (Front, Rear and Steering), IAB, SLR steering, K&N Filter (Resonators Removed), EBC Front Pads, 12v-110 +USB inverter, Optima Yellow d34/78, Side-Step Delete, Clutch-Start override switch, E-Fan Conversion, 4x Roof Mounted Hellas, Interior Organization Box, Redline (TX, X-Fer, Diff), Toyo Open Country ATs (265/75-16) on Steelies & R2-D2
Swordfish is offline
post #7 of 9 Old 11-18-2009, 08:17 PM Thread Starter
wetzie
I thought about shutting down the pump like old school but I was worried about too mauch damage and a lot of mountain highways. I will try the resue tape and see how that works. I also found the part for $220 so I may try repairing it completely. Is it a tough repair, it seems it is just two bolts?
thanx everyone
wetzie is offline
post #8 of 9 Old 11-18-2009, 08:35 PM
Swordfish
Swordfish's Avatar
Technically speaking, yes the only critical bit are those two nuts. Two other bolts holding the line in place. However you'll need to bleed out the system well.
- Jon
post #9 of 9 Old 11-19-2009, 05:24 AM
punkrockdrummerx
if you yanked the line and got all the fluid out of the system and drove it home old school you would then also need a new pump unless you took the belt off the pump
-Kyle
2001 Jeep Wrangler
