ECU reset??? - Nissan Xterra Forum
post #1 of 12 Old 10-30-2009, 05:58 PM Thread Starter
Larry710
Seasoned
N/A Xterra
Larry710 is on a distinguished road
ECU reset???
So I pulled my cover off the air box, to have a look at how clean or dirty the throttle body was.
When I reinstalled the cover I forgot to plug in the MAF sensor. As soon as the Service Engine Soon light come on, I remembered pretty quick. I shut it down, popped the hood and plugged it back in. But the light has not gone out!!!
Other vehicles, I have disconnected the battery. I have tried this, but still on.
is there a way to reset the ECU?
Larry710 is offline
N/A Xterra
post #2 of 12 Old 10-30-2009, 06:06 PM
dejablue
dejablue's Avatar
Quoted: 242 Post(s)
2003 Xterra
dejablue is a glorious beacon of light dejablue is a glorious beacon of light dejablue is a glorious beacon of light dejablue is a glorious beacon of light dejablue is a glorious beacon of light
how long did you unplug it for?
dejablue is offline
2003 Xterra
post #3 of 12 Old 10-30-2009, 06:21 PM Thread Starter
Larry710
Seasoned
N/A Xterra
The MAFS... 15-20 mins
Battery... 5-10 mins
Larry710 is offline
N/A Xterra
post #4 of 12 Old 10-30-2009, 06:40 PM
nn87
nn87's Avatar
nn87 is on a distinguished road
I had something like that. Found an aswer on this forum a while back. I remember you had to turn the ignition one click over 3 or 4 times and then it cleared the SES light.
2001 XE, V6, 4X4.
Front and rear Billsteins.
Rear AC shackles.
Front end 3'' SL from AC.
BFG AT KO 32x11.5x15.
Intake mod with K&N air filter. SOLD
2006 SE, 4X4. Ditched stepbars.
265-70-17 Wrangler DuraTracs.
nn87 is offline
post #5 of 12 Old 10-30-2009, 06:46 PM
dejablue
dejablue's Avatar
Quoted: 242 Post(s)
2003 Xterra
5 or 10 is not long enough 1 hour
dejablue is offline
2003 Xterra
post #6 of 12 Old 10-30-2009, 10:09 PM Thread Starter
Larry710
Seasoned
N/A Xterra
Ok thanks... I'll try both
Larry710 is offline
N/A Xterra
post #7 of 12 Old 10-30-2009, 10:44 PM
recon
recon's Avatar
recon is on a distinguished road
try for an hour or 2 and you should be good.
Evan
00' yellow x
31" BFG A/T KO
AC IAB
AC Shackles
Bilstein's all around
recon is offline
post #8 of 12 Old 10-31-2009, 04:44 AM
Xterra Mike
Silver Submarine
Xterra Mike's Avatar
Quoted: 14 Post(s)
2001 SE Xterra
Xterra Mike is a jewel in the rough Xterra Mike is a jewel in the rough Xterra Mike is a jewel in the rough Xterra Mike is a jewel in the rough
Garage
How did your X run with the MAF sensor unpluged? mine just stalls.
Xterra Mike is offline
2001 SE Xterra
post #9 of 12 Old 10-31-2009, 10:52 AM
ab09
Seasoned
ab09's Avatar
Quoted: 1 Post(s)
ab09 is on a distinguished road
unpluging the battery or start it a few times.. If its your DD it should be off in a few days if you drive it normaly
ab09 is offline
post #10 of 12 Old 11-01-2009, 09:07 AM Thread Starter
Larry710
Seasoned
N/A Xterra
I only started it breifly with it unplugged. I noticed the light on right away and shut it off. I didn't notice any effect in having it unplugged.
I disconnected the battery overnight, and walla... no more light.
thanks for the info
Larry710 is offline
N/A Xterra
