rear wiper blade - Nissan Xterra Forum: Xterra Forums
Old 09-30-2009, 02:00 PM
yoyofool2 yoyofool2 is offline
Member: #8990
2005 Xterra
yoyofool2 is on a distinguished road
rear wiper blade
i went to kragen this morning to get all new wipers. the fronts went on fine but the rear wiper blade is weird. what brand wiper blades are you guys using on the rear?
Old 09-30-2009, 02:19 PM
Roschili's Avatar
Roschili Roschili is offline
Member: #8077
Roschili has a spectacular aura about themRoschili has a spectacular aura about them
Duralast, or whatever the Autozone brand is. Works just fine for me. I think its 14in...
-Drew
2000 Nissan Xterra SE
>Build Thread<
-Sony CDX-GT930UI Head unit w/ Alpine Type-R 6.5s and 6x9s
-BFG A/T KOs, Bilsteins
Old 09-30-2009, 02:49 PM
TimRich's Avatar
TimRich TimRich is offline
Spaz
Member: #2811
TimRich has a spectacular aura about themTimRich has a spectacular aura about themTimRich has a spectacular aura about them
Yep just the el cheapo from the parts store. I think it's a 14 inch too...
Tim... 2000 Xterra SE 4x4
Mods: K&N Air Filter, AC PML, 17" Pro Comp Wheels, 33" Wild Country MTX, Custom Rear Bumper w/Tire Carrier, 2 inch BL, Hella 500FF's, AC Prerunner bumper, Xoskel light bar with 4 KC Daylighters, AC's IAB, Rancho RS5000 Shocks.
Official Build Thread
Old 09-30-2009, 02:57 PM
Member: #8990
2005 Xterra
i tried the duralast one and it cant mount to the wiper arm. maybe its a second gen thing?
Old 09-30-2009, 03:43 PM
Roschili's Avatar
Member: #8077
Maybe...I'm first gen. Some of the 2nd gen guys will chime in and help you.
-Drew
>Build Thread<
Old 10-01-2009, 12:31 PM
Member: #8990
2005 Xterra
oh ok i found the correct blades at pepboys, but you have to get the ones designed for the "rear" since they use a different clasp than the standardized clasp used on the front wipers. stock the 2nd gens use a 12 inch rear wiper blade, but it will fit a much bigger one, i went with 14 inch.
Old 06-06-2010, 02:12 AM
AZ-Ted's Avatar
AZ-Ted AZ-Ted is offline
Member: #1603
2006 XOR Xterra
AZ-Ted is on a distinguished road
Yep, the 2nd Gen has a goofy rear wiper mount. I'm only aware of either the dealer part, or the Trico Exact Fit Rear Wiper. You can go to the 14" without any issues. I just installed the Trico 14-B (fits a Murano).
The stock rear wiper (12") on top of the Trico 14-B (14"):
'06 4x4 OR; Titan Swapped; Fully Shrocked; Xoskel Full Replacement Rack, etc., etc. Future Mods: Warn winch, dual battery setup, and air horns.
  #8
Old 06-06-2010, 09:56 AM
J Everett's Avatar
J Everett J Everett is offline
Member: #4974
2008 Xterra
J Everett is a jewel in the roughJ Everett is a jewel in the roughJ Everett is a jewel in the rough
Yeah, the second gens have a strange rear wiper. A lot of us use the the blade from a Murano, which is 14" instead of the stock 12" but otherwise fits perfectly, and sweeps a little more real estate on the back glass.
--Jason
My 2008 Super Black SE "The Elephant"
The ass of my ride will swap ends faster than the OP will fail an English class.
  #9
Old 06-06-2010, 02:25 PM
Loki512's Avatar
Loki512 Loki512 is offline
Member: #10796
2009 S Xterra
Loki512 is on a distinguished road
i rigged it to run an 18" blade. put a screw with washers through the center hole in the wiper arm, nut to tighten it down so it won't slide out of the slot, new blade slides over the screw and a cap nut tightens that down. you have to make sure that the new blade has a center hole for the "pin-through" type arms. i also took a zip tie and tightened the spring on the arm since the 18" beam-type blade wants to push off the center. works great and i can see out the whole rear window
