Hot and Wet Passenger Side Floorboard? - Nissan Xterra Forum
post #1 of 6 Old 08-25-2009, 08:35 PM Thread Starter
OffRoadWanderer
08 OffRoad Xterra
OffRoadWanderer is on a distinguished road
I own a 08 XTerra Off Road and recently noticed the passenger side floorboard was unusually hot. I would like to know if this is normal or if something is wrong? Wondering if the heat is from the exhaust? I know when I had a C5 Vette the center console area got hot from the exhaust due to thin insulation. Also, the same area has been damp off and on. Is it possible I'm getting water backed up from the A/C or something else? Or do I simply have a leak somewhere? Thanks.
OffRoadWanderer is offline
08 OffRoad Xterra
post #2 of 6 Old 08-25-2009, 09:17 PM
json3904
ADMIN
json3904's Avatar
Quoted: 1 Post(s)
json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of json3904 has much to be proud of
i would say you have a leak.... but i do not own a 2nd gen X so i couldn't help you look for the problem....
**New site rules and guidelines** Click Here
json3904 is offline
post #3 of 6 Old 08-25-2009, 10:21 PM
soccerbrace
blah blah blah
soccerbrace's Avatar
Quoted: 1 Post(s)
soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold
Is it coolant?
Photobucket
soccerbrace is offline
post #4 of 6 Old 08-25-2009, 11:02 PM
J Everett
J Everett's Avatar
2008 Xterra
J Everett is a jewel in the rough J Everett is a jewel in the rough J Everett is a jewel in the rough
I would imagine the heat is from the transfer case or transmission and the dampness is condensation from the AC vents dripping on the floor. Do you notice the dampness after the AC has been blowing cold for a long while? I know it's been hot up in New England a lot lately. How's the humidity been?
Either that or your heater core is leaking coolant. But you should be able to identify that by smell.
--Jason
My 2008 Super Black SE "The Elephant"
The ass of my ride will swap ends faster than the OP will fail an English class.
J Everett is offline
2008 Xterra
post #5 of 6 Old 08-29-2009, 11:50 AM Thread Starter
OffRoadWanderer
08 OffRoad Xterra
Ok. If the heat is from the transfer case and/or transmission is this something that is normal? I am not getting an overheat light of any kind. As for the dampness....it does not smell like coolant so I highly doubt that's it. It could be condensation from the A/C as I have been using it. However, wouldn't the driver's side be damp as well?
Any other suggestions/answers? Thanks.
08 OffRoad Xterra
post #6 of 6 Old 05-31-2010, 06:29 PM
pavement fever
pavement fever's Avatar
2007 S Xterra
pavement fever is on a distinguished road
The exhaust does run underneath the passenger side floor board and even with the heat shield my 07 xterra does get a little warm. I also noticed the my dampness issue was caused from the drainage valve from the AC. The drain water would run along the exiting pipe and circle back into the firewall causing the carpet to become damp after running the AC. I ended up taking a small hose extender to the end of the exiting valve to stop the water from flowing along the pipe back into the firewall. I hope this is clear I can send pictures of the fix if needed.
Damian
pavement fever is offline
2007 S Xterra
