How to change Fuel Filter! PLZ - Nissan Xterra Forum
post #1 of 8 Old 08-03-2009, 04:22 PM Thread Starter
Blacky04
Blacky04 is on a distinguished road
Hello!!
I just bought a new Fuel Filter, and at NTB they charge $80. Just wanted to know if Anyone could please tell me how to change it!!
Thanks =]
Blacky04 is offline
post #2 of 8 Old 08-03-2009, 05:32 PM
fusionfronty99
fusionfronty99's Avatar
Quoted: 2 Post(s)
99' Xterra
fusionfronty99 is on a distinguished road
fusionfronty99 is offline
99' Xterra
post #3 of 8 Old 08-03-2009, 07:57 PM
saberz
saberz's Avatar
saberz is on a distinguished road
Its very easy to change, just make sure you put a drain pain/plastic on the ground before doing so, wear some eye protection in case the filter slips and the gas starts a pouring on your face(yes it happened to me).
Basically you pull the fuel pump fuse out of the truck(located in the driver side fuse box inside the truck). Start the truck until it stalls, start it again to make sure it stalls fully so no gas is in the system(less fuel spillage).
The fuel filter is located near the mid/rear section of the passenger side. Its before the rear wheel behind a metal cover plate thats facing towards the front fo the truck. You will see two gas lines one on each side of it running behind the cover plate. Just unscrew the cover plate, loosen the two tubs on both sides of the filter and pull the right side out first from what im told, use a golf tee to plug it up and then work off the other side and do the same thing. Take note of how the filter is set up because u need to put in that same way. Remove the bracket off the old filter and mount it onto the new one. Put it all together, if you have trouble sliding the tubes back onto the filter just use some gas/vasoline(not much) to help lube the tube onto it. Put it together, put the fuse back in, start it up and check for leaks.
It took me 15 minutes and I've never changed a filter before, I just looked at a picture and read about it on this forum.
Look for this under the area I said, unbolt that and you should be able to see it. Can thank Dezurtrat for that pic, he took a really nice snapshot of it.
-Anies-
2004 Nissan Xterra XE V6
+Front/Rear Bilstein Shocks
+Bilstein Steering Stabilizer
+Kumho Road Venture APT 265/70R16
+Intake Modification + OE/Filter
+Maglite Installl
saberz is offline
post #4 of 8 Old 08-03-2009, 08:59 PM
mepstein369
Seasoned
mepstein369's Avatar
mepstein369 is on a distinguished road
very easy to do. did it last sunday. i was nervous at first, but was pretty simple. only had a minor amount of gas come out of the hoses. get a pick tool (i don't know if that is what it is called) to get underneath the rubber hose and then just pull it off the old filter.
Took about 15 minutes.
mepstein369 is offline
post #5 of 8 Old 08-04-2009, 08:58 AM
dejablue
dejablue's Avatar
Quoted: 242 Post(s)
2003 Xterra
dejablue is a glorious beacon of light dejablue is a glorious beacon of light dejablue is a glorious beacon of light dejablue is a glorious beacon of light dejablue is a glorious beacon of light
make sure you take the gas cap of the fill tube before you start or the gas will never stop coming out.
dejablue is offline
2003 Xterra
post #6 of 8 Old 10-01-2010, 09:49 AM
BoarderPhreak
BoarderPhreak is on a distinguished road
There's a detailed HOW-TO over on Xterra Firma called "Replacing the Fuel Filter" which covers the years 2000-2003.
BoarderPhreak is offline
post #7 of 8 Old 10-01-2010, 10:05 AM
RawkerStatus
RawkerStatus's Avatar
RawkerStatus is on a distinguished road
theres also a DIY on here. its listed in the list of how tos thread.
Conveniently off the 10 and 210 in San Dimas... no not really
RawkerStatus is offline
post #8 of 8 Old 07-12-2015, 09:46 AM
Mama3
Mama3 is on a distinguished road
I have an 07 model and we cannot find the fuel filter on it any suggestions?
Mama3 is offline
