Evap Control system - Nissan Xterra Forum
post #1 of 11 Old 06-06-2009, 05:52 PM Thread Starter
modxterra
modxterra's Avatar
modxterra is on a distinguished road
Evap Control system
I got some warrenty work done at the dealer for the cat going bad and then the next morning the ses light came on again. went to autozone and came out with P0441, P0448, and P0455. all of these linking to the evap system. did some searching and alot of you were talking about the gas cap. anybody have a different solution other then that?
Travis
2004 Red 4X4 AT
Yakima Roof Rack
Bilstein Shocks and Steering Stabilizer
33x12.5 General Grabber Red Letters
AEM Cold Air Intake
AC 2" BL with AC pml
HD TRAs
Idle Arm Brace
Shrock Front and Rear
Rocky Road Outfitters Super Sliders
modxterra is offline
post #2 of 11 Old 06-07-2009, 04:30 PM Thread Starter
modxterra
modxterra's Avatar
ok i checked the gas cap. cleaned it from any debris and cleared the codes and now only the P0441 is coming back up today. any suggestions?
Travis
2004 Red 4X4 AT
Yakima Roof Rack
AEM Cold Air Intake
HD TRAs
Idle Arm Brace
post #3 of 11 Old 06-10-2009, 07:14 PM Thread Starter
modxterra
modxterra's Avatar
can somebody at least tell where the evap cannister is. a pic if possible thanks
Travis
2004 Red 4X4 AT
Yakima Roof Rack
AEM Cold Air Intake
HD TRAs
Idle Arm Brace
post #4 of 11 Old 06-10-2009, 07:33 PM
jclmaster
jclmaster's Avatar
2001 / SE Xterra
jclmaster is on a distinguished road
Here you go.
jclmaster is offline
2001 / SE Xterra
post #5 of 11 Old 10-22-2010, 01:28 AM
atticcam
atticcam's Avatar
2007 Xterra
atticcam is on a distinguished road
Repair Fault Code P0448
E-mail me at camattic@shaw.ca. I will send you a PDF of complete instructions of how to diagnose and repair your EVAP canister and vent valve
atticcam is offline
2007 Xterra
post #6 of 11 Old 10-22-2010, 03:25 AM
jpeeps
jpeeps's Avatar
jpeeps is on a distinguished road
I have the same code on my X. Check all your hoses and hookups in the EVAP system for leaks and broken connections. Also if you smell gas fumes around the rear of the vehicle after you shut off the engine, then it's good indication that the EVAP system is not working correctly. I broke one of the little plastic vacuum cutoff valves in the back by the canister when i was reinstalling my passenger side leaf pack. Haven't replaced it yet because it's $95 for a small plastic connector, but the code popped up soon after it broke. Hopefully that gives you some place to start.
jpeeps is offline
post #7 of 11 Old 10-22-2010, 06:50 AM
Jmac289GT
Jmac289GT's Avatar
Jmac289GT is on a distinguished road
Im thinking after a year he has probably solved this by now...I hope!
Jmac289GT is offline
post #8 of 11 Old 11-06-2010, 06:44 PM
atticcam
atticcam's Avatar
2007 Xterra
The problem never really goes away. When the code stops coming up, you will probably notice that it takes a little longer to fill your tank. Means that the valve is stuck closed
atticcam is offline
2007 Xterra
post #9 of 11 Old 11-15-2010, 07:11 AM
ka7jjg43
ka7jjg43 is on a distinguished road
My check engine soon light has come on for the 3rd time, replaced the gas cap after the second time,how much do those engine code scanners cost for a nissan?? we don't have any autozone shops in my area.
Just got one, displayed engine P0455, gross evap. leak.
Time to check my Xterra service manual, EC.pdf pg # 32
Well it just cleared on it's own the check engine soon light???
Always thought these code alarms couldn't reset that way???
ka7jjg43 is offline
post #10 of 11 Old 11-15-2010, 01:17 PM
sionnach
2000 v6 SE Xterra
sionnach will become famous soon enough
From what I can tell the check engine lights will reset if you go 50 miles without having the same issue again.
e.g. it takes two instances for it to throw a code (like a knock sensor or misfire) then you drive a bit and it'll reset if it doesn't happen again.
Code readers are relatively cheap.
Costco has one for $90.
I'll sell you mine for $60 + shipping. (used once Innova reader - need to upgrade to a scangauge myself)
hope this helps.
Todd
Seattle, WA
~85k miles (nov 2010)
[X] RED LED map lights [X] Thor Mod [X] PML [ ] Total Chaos IAB [X] Bilsteins [X] 32x11.50R15/C BFG A/T KO [ ] Tail Light Covers [ ] lighting package (top bar and bumper mount) [ ] UCA & AAL to finalize SL
[ ] Shrock front bumper [ ] “ Rock sliders [ ] “ Front skid plate [ ] “ Engine skid plate [ ] “ Tcase skid plate [ ] “ Gas tank skid plate [ ] “ Rear bumper [ ] Convert all stock lights to LED
sionnach is offline
2000 v6 SE Xterra
