removing ac high pressure line from condensor? - Nissan Xterra Forum: Xterra Forums
Old 06-05-2009, 05:38 AM
ptbo_hunter ptbo_hunter is offline
Member: #5516
ptbo_hunter is on a distinguished road
Hi I was wondering if anyone has any insight as to how to remove the ac high pressure line from the condensor? I think it's the condesor, it looks like a rad? Anyways, it has two hoses going in one being the high line and it looks like it has a 1/4" plate with a nut. I'm assuming I loosen the nut and the plate comes off. However I bought the new line and the end is already flared with the o-ring, how do you get the plate over the flared end? I haven't actually looked at it close.
Thanks
Old 06-05-2009, 07:57 AM
Ricer-X's Avatar
Ricer-X Ricer-X is offline
WHO DAT
Member: #51
Ricer-X has much to be proud ofRicer-X has much to be proud ofRicer-X has much to be proud ofRicer-X has much to be proud ofRicer-X has much to be proud ofRicer-X has much to be proud ofRicer-X has much to be proud ofRicer-X has much to be proud of
i havent taken mine off yet, but i do need to replace it
how much did that line cost you?
Dustin - 2004 XE V6 2wd; 3" SL, 2" BL, 33x12.5" ATs, HooHaa Steering, Idler arm Brace, 5% tint, Bilstein HD shocks, SAW Tbars, 1/2" ball joint spacers, piaa, HD Tbar anchors, B&M Tranny Cooler Stock Intake Mod, blacked out plastics/wheels/rack
Old 06-05-2009, 08:48 AM
Member: #5516
I'm Canadian eh. So it cost me about $60, from the Nissan dealer.
Old 06-05-2009, 08:50 PM
silverbullet's Avatar
silverbullet silverbullet is offline
ASE Certified
Member: #2959
silverbullet will become famous soon enoughsilverbullet will become famous soon enough
Your talking about the line that runs from the compressor to the condenser? It should have the solid aluminum block fittings with the bolt hole in it already installed. all you do is take the bolts out of each end and pull the hose out. Lube up the new O-ring and install the new hose and install. Then vacuum down your AC system to check for leaks and get the moisture out. And fill.
BTW you should replace the receiver/drier if your opening the system since your X is over 5 years old.
Dustin I think mine was $77 shipped from Courtesy.
Old 06-05-2009, 09:22 PM
Ricer-X's Avatar
WHO DAT
Member: #51
sigh, looks like ill be out of ac for a while longer now
Old 06-05-2009, 09:34 PM
ASE Certified
Member: #2959
Just keep buying 1LB cans and adding to it. Just don't put stop leak in it. That crap doesnt stop any AC leak. lol
Maybe james can hook you up?
Old 06-05-2009, 09:53 PM
Ricer-X's Avatar
WHO DAT
Member: #51
no man, my shit will all leak out in 20min or so
it gets hot as big shit down here, lol
i stop the leak in one place., it leaks in another, maybe ill just jb weld the whole damn high pressure side together, lol
