2011 Xterra FM Modulator - Nissan Xterra Forum
post #1 of 5 Old 06-22-2016, 08:33 PM Thread Starter
Mad_Jasper
Quoted: 2 Post(s)
Integrated non-RF stereo. I spiced the factory antennae cable into a Scoshe FM modulator. Probably should not have done that. Radio will not power on. I replaced the fuses, still no joy. Is there any reason that I am missing as to why the radio will not power on without the antennae plugged in?
Mad_Jasper is offline
post #2 of 5 Old 06-23-2016, 06:22 AM
Beer
Beer's Avatar
Quoted: 3 Post(s)
2010 Xterra
I replaced the radio on my 2010 and bypassed the existing FM modulator and it works fine. I don't think it has anything to do with your power supply. Check your wiring and radio fuse. Did you use an adapter harness? I did, couldn't be easier.
2001 Porsche Boxster S
2010 Nissan Xterra S
Always get the S.
Beer is offline
2010 Xterra
post #3 of 5 Old 06-23-2016, 06:43 AM Thread Starter
Mad_Jasper
Quoted: 2 Post(s)
I probably should not have been drinking before doing this. The antenna cable contains a ground wire. I didn't notice the tiny wire until this morning.
post #4 of 5 Old 06-23-2016, 07:19 AM
Beer
Beer's Avatar
Quoted: 3 Post(s)
2010 Xterra
Glad you found an easy fix. Everyone knows beer makes you smarter.
Always get the S.
Beer is offline
2010 Xterra
post #5 of 5 Old 06-23-2016, 08:01 AM Thread Starter
Mad_Jasper
Quoted: 2 Post(s)
Sadly, with the antenna wire cut, not so easy. At least for me. I had to remove the antenna wire from the connector and uncrimp the in. The single strand wire that carries the RF signal is machine-crimped into a fork-shaped connector that is about the size of an ant. There's no way to remove the wire that I can see. So I am going to attempt to solder the wire on the connector and put everything back together. If it works, I'll probably replace the head unit with one that has an AUX option.
Thanks!
