Nissan Xterra Fog Light LED Bulbs! See Installed Pictures! Plug & Play Install - Nissan Xterra Forum
post #1 of 61 Old 04-01-2015, 10:24 AM Thread Starter
Diode Dynamics
Supporting Vendor
Diode Dynamics's Avatar
Quoted: 3 Post(s)
Diode Dynamics is on a distinguished road
Arrow Nissan Xterra Fog Light LED Bulbs! See Installed Pictures! Plug & Play Install
We carry LED bulbs for replacement of your Xterra fog lights, in all major sizes. They are available in HP, XP, and XML styles. Just simple plug and play, replace the bulb and you are good to go!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not raise prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
Diode Dynamics offers several bulb model options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 265 lumens. Slightly lower brightness than factory.
XP80: 510 lumens. Similar brightness to factory.
XML2: 1410 lumens. Much brighter than factory. These are bright!
*XML2 is available in 3000K Yellow / 4000K / 5000K / 6000K Color Temperatures
Bulb Design:
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
XML2: NEW! Two opposing genuine CREE XM-L2 chips, driven at high power by self-contained regulator unit, in an attractive cast-aluminum housing. Fully waterproof, non-polar, modular design.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your Xterra).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
2005-2015 Nissan Xterra
If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics is offline
post #2 of 61 Old 04-08-2015, 02:45 PM
Cruecible
Cruecible's Avatar
Quoted: 7 Post(s)
Cruecible is on a distinguished road
I assume these wouldn't fit the '03 or '04 fog lights? If they did, I'd be all over those ultra bright yellow ones
2004 Super Black SE S/C -=KCCO=-
Cruecible is offline
post #3 of 61 Old 04-08-2015, 03:22 PM Thread Starter
Diode Dynamics
Supporting Vendor
Quoted: 3 Post(s)
We actually do have the Yellow halogen replacements in the 2003/04 model year sizes
Feel free to give us a call for more information: (314) 205-3033
Nick C.
post #4 of 61 Old 04-08-2015, 03:45 PM
Cruecible
Cruecible's Avatar
Quoted: 7 Post(s)
Nick C.
Will do! Thank you!!
post #5 of 61 Old 04-08-2015, 03:47 PM Thread Starter
Diode Dynamics
Supporting Vendor
Quoted: 3 Post(s)
You're welcome!
Nick C.
post #6 of 61 Old 04-10-2015, 11:29 AM
bossX
Seasoned
bossX's Avatar
Quoted: 55 Post(s)
2001 SE Xterra
bossX is on a distinguished road
Nick C.
Would this also fit an 01 with the square foglight? Also, if I went with the highest output bulb for the fogs, should there be a concern of excess heat and possibly damaging my PLASTIC stock lenses?
bossX is offline
2001 SE Xterra
post #7 of 61 Old 04-10-2015, 01:22 PM Thread Starter
Diode Dynamics
Supporting Vendor
Quoted: 3 Post(s)
The 2000-2002 Xterras use a much smaller bulb size than the newer generations. The H3 isn't available in the XP or XML2 styles, but they don't create excessive heat or risk damaging the factory housings.
It's difficult to develop a bright H3 LED replacement because of the size constraints and heatsink requirements
Our LED H3 options are strictly cosmetic upgrades right now.
Nick C.
post #8 of 61 Old 04-10-2015, 03:16 PM
bossX
Seasoned
bossX's Avatar
Quoted: 55 Post(s)
2001 SE Xterra
I see, thank you very much. Looking for greater light output and not just looks.
bossX is offline
2001 SE Xterra
post #9 of 61 Old 04-10-2015, 03:38 PM Thread Starter
Diode Dynamics
Supporting Vendor
Quoted: 3 Post(s)
Id' stick with halogen or a 35 watt HID conversion kit
Nick C.
post #10 of 61 Old 05-14-2015, 12:58 PM
poppaX
Seasoned
poppaX's Avatar
Quoted: 28 Post(s)
2002 SE SC Xterra
poppaX is on a distinguished road
Garage
Wow those look cool. Especially the XML2 5000K.
So these fit 00-04 Xterras and ship to Canada?
Thanks
Current Mods
[x] Tires and Rims (Duratracs with Black Tomahawks)
[x] 22" Light Bar (Inline Fuse and Rocker switch)
[x] Hi-Lift Jack mounted
[x] Timing Belt and Water pump replacement
[x] Remove Step Rails - Sway Bar
[x] Blacked emblems and taillights
[x] Shrockworks Front Bumper
[x] Bilstein 4600's.
Future Mods
[ ] Shrockworks Front Skid Plate
[ ] Shrockworks rear tire Carrier
[ ] Upgraded Coils
[ ] Trail Gear 58" Sliders
[ ] 2" BL and 33" Duratracs
poppaX is offline
2002 SE SC Xterra
