2 inch body lift pics - Page 7 - Nissan Xterra Forum
post #61 of 63 Old 09-07-2013, 11:39 AM
Ryandrew
Ryandrew's Avatar
Originally Posted by yellowx16 View Post
nah you ca do 33s with just a 3"sl on a 00-04. you just might get some contact when you're offroad. if it's strictly street driven you will be fine, you will just need to do a bit of trimming.
Sent from AutoGuide.com Free App
This is true, but you will prob still rub quite often going over bumps, turning, etc...depending on the width of the tires and BS of the rims
Sent from AutoGuide.com App
2004 Silver XE V-6 4x2
Inside: Pioneer HU w/ Bluetooth, Pioneer 6.5's, Kicker 12" sub, Kicker 250 amp
Outside:2" DIY BL, AC Shackles, Calmini UCA's and AAL, Calmini IAB, AC HD TRA's, Bandit IA bushings, Bilstein shocks around, 15x8 MB TKO wheels with 33x12.5 Duratracs, Bedlinered plastics, Plastidipped emblems, OEM add on fog lights, 20" LED lightbar, Cherry Bomb glasspacks, blacked out tail lights
Under the Hood: Stock air intake mod w/ K&N drop in
Ryandrew is offline
post #62 of 63 Old 09-07-2013, 12:01 PM Thread Starter
yellowx16
yellowx16's Avatar
yea that's a huge factor. if you keep stock rims you should be good, anything with less back spacing is where you might run into bigger problems.
Exterior:
Custom rear bumper and tire carrier, ARB Front Winch bumper, Calmini PML, 2" Body Lift, HID projector retrofitted headlights, 4 5" pro comp spot lights on custom light bar, 2 6" Pro Comp lights converted to HID, 2 Rigid Industries Dually flood lights, 31x10.50416 BFG A/T on 16x8 Vision Wheel Warrior
Performance:
K&N Cold Air Intake, Flowmaster super 44 muffler, full replacement exhaust
Build-http://www.clubxterra.org/forums/sho...d.php?p=510153
yellowx16 is offline
post #63 of 63 Old 09-12-2013, 06:52 AM
roco_roy
my X is 2002, and its tires are 265/75/R17... it is an SE, probably i won't have to much rubbing on it, so, the best thing that i can do is to use 2" BL and 3"SL.i was wondering if i use a 2" BL can use 33" (it is less $$ the BL)
roco_roy is offline
For the best viewing experience please update your browser to Google Chrome
