Replaced the Distibutor now no crank - Nissan Xterra Forum
post #1 of 6 Old 01-20-2017, 07:53 PM Thread Starter
Braydon Whitlock
I replaced the Distributor last week. After placing the new one in and reattaching the battery leads I tried to turn over the Xterra. Got nothing. There is a click and the fuel pump kicks on but the engine doesn't even try to crank. Tried a new battery and still had the same issue. Broke down and put the old parts back in and still had the same issue. I jump started the car and was able to get it to run and it ran perfectly!! I mean no rough idle or running at all. Turned the car off and tried to turn it back on but immediately got just click and the fuel pump again. Fuses seem to be good and all so no clue what else it could be
PLEASE HELP!
Braydon Whitlock is offline
post #2 of 6 Old 02-01-2017, 05:50 PM
bradjinks
Based on that I would suspect the battery. If I were you I would have the battery tested first.
bradjinks is offline
post #3 of 6 Old 02-01-2017, 05:54 PM
JLBinHSV
Seasoned
Quoted: 42 Post(s)
Sounds like your battery might have a bad ground connection.
JLBinHSV is offline
post #4 of 6 Old 02-07-2017, 10:11 AM
VTCMart
VTCMart's Avatar
Quoted: 4 Post(s)
Clean the battery connections? Wire brush and CocaCola works great
VTCMart is offline
post #5 of 6 Old 02-07-2017, 06:48 PM
cbxterra
Quoted: 31 Post(s)
Garage
X2 on connections. Clean the battery and also the starter connections. My guess is a bad connection. Or maybe the alternator so the battery doesn't get a charge. I'd start by inspecting and cleaning the battery connections. If you do the starter connections disconnect the battery first. It's too easy to cross it by mistake and get sparks
cbxterra is offline
post #6 of 6 Old 03-20-2017, 04:29 PM
A_Villa01
Im having the same problems. New battery and all, alternator is fine. Im assuming I need to replace the wires. Did you find the problem OP?
A_Villa01 is offline
