Nissan Xterra Interior LED Lighting! See Installed Comparison Photos! - Nissan Xterra Forum
post #1 of 8 Old 10-23-2015, 10:03 AM Thread Starter
Diode Dynamics
Supporting Vendor
Diode Dynamics's Avatar
Quoted: 3 Post(s)
Diode Dynamics is on a distinguished road
Arrow Nissan Xterra Interior LED Lighting! See Installed Comparison Photos!
At Diode Dynamics, we carry a full line of LED bulbs, to replace your Xterra's dome lights, license plate lights, trunk light, turn signals, and more!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Your dome, map, and cargo lights use an incandescent bulb from the factory, giving it a yellowish color. By replacing them with an LED, you can add a luxurious and modern look to your Xterra, with a cool white color, just like the lights on newer luxury vehicles. You can also increase the brightness with SMF4 or SMD12 Board, to improve the performance of your dome light.
The installation is 100% plug-and-play, just replace your factory bulbs!
Bulb Design:
SMF2: This bulb has a standard festoon base, with two forward-facing 5050-size Epistar SMDs. Direct replacement, plug and play.
SMF6: Standard festoon base, with six 5050-size Epistar SMD chips arranged on a rectangular panel.
SMD12 Board: This is an LED panel, fitted with 12 5050-size Epistar SMD chips. Comes with spring-loaded festoon-style adapter for direct installation. Plug the adapter into the bulb socket, then just stick the board in place with the mounting adhesive pad. The board-and-adapter design allows for extremely high brightness compared to a simple bulb.
Brightness
SMF2: (16 lumens) Slightly lower brightness than OEM bulbs, but still provides the crisp, modern color of LED.
SMF6: (94 lumens) Slightly higher brightness than OEM bulbs.
SMD12 Board: (118 lumens) Much brighter than OEM bulbs. These are bright!
Lumens: BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
All products by Diode Dynamics are backed by a 30-day satisfaction guarantee and a three-year limited warranty.
Dome Light LED for 2000-2015 Nissan Xterra
Map Light LEDs for 2005-2015 Nissan Xterra (pair)
Trunk LED for 2000-2015 Nissan Xterra
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
Diode Dynamics is offline
post #2 of 8 Old 10-28-2015, 11:44 AM
bossX
bossX's Avatar
Quoted: 55 Post(s)
2001 SE Xterra
bossX is on a distinguished road
hello, is there a reason there is no map lights available for the 1st Gen Xterra?
Thanks!
2001 xterra SE
Mods:
- air freshner
- new wipers
bossX is offline
2001 SE Xterra
post #3 of 8 Old 10-28-2015, 12:11 PM Thread Starter
Diode Dynamics
Supporting Vendor
Quoted: 3 Post(s)
Thanks!
We are still updating the site listings
They use the same bulb sizes as the newer model years
Nick C.
post #4 of 8 Old 04-12-2017, 07:13 AM Thread Starter
Diode Dynamics
Supporting Vendor
Quoted: 3 Post(s)
Customer Submitted Photo - Pro4X
post #5 of 8 Old 05-23-2017, 08:38 AM
Xterra816
2015 Xterra
Xterra816 is on a distinguished road
Just ordered a full replacement set, Map, Dome and Trunk. Can't want to get them in and installed.
Xterra816 is offline
2015 Xterra
post #6 of 8 Old 05-23-2017, 08:39 AM Thread Starter
Diode Dynamics
Supporting Vendor
Quoted: 3 Post(s)
Thank you for your support!
Looking forward to seeing everything installed!
Nick C.
post #7 of 8 Old 05-23-2017, 09:49 AM Thread Starter
Diode Dynamics
Supporting Vendor
Quoted: 3 Post(s)
RGB Footwell and Grille Lighting Kit shown on our 2016 F-150 SEMA Build
post #8 of 8 Old 05-26-2017, 04:27 PM Thread Starter
Diode Dynamics
Supporting Vendor
Quoted: 3 Post(s)
Our authorized dealers will be running Memorial day specials this weekend, check out our locator tool:
Diode Dynamics Dealer Locator Map
Thanks!
Nick C.
