2004 Xterra what fluids to change and what to use - Nissan Xterra Forum
post #1 of 1 Old 01-09-2017, 12:00 AM Thread Starter
Chase Hicks
Chase Hicks is on a distinguished road
Post 2004 Xterra what fluids to change and what to use
Ok so so just got a 2004 Xterra with 104k miles on it about 3 weeks ago. Me and my dad did the timing belt maintenance today and man did it need it, it had a lot of slack in the belt and the belt showed signs of wear. My next task is to do all fluids which I think are as follows transfer case,front and back diffs, transmission fluid and engine oil change. I wanted to make sure these are all I need to change as far as fluids go and also what type of fluid do I need for the diffs front and back and what type of fluid for the transfer case and transmission?
Plugs, wires, distributor cap, and rotary cap are next on my list after fluids are taken care of.
Chase Hicks is offline
Tags
differential fluid , fluids , maintenence , oil change , transfer case
