In stock form no they will not, the hub size is too small. You can get them bored out by a machine shop i've seen it done and almost did myself but in the end it was too much work.
You know at first i thought the Titan wheels wouldn't fit the 1st gen's but according to the specs the lug pattern and backspacing are the same. Doesn't say anything about the hub size. I guess you find out when you get them shipped to you. That sucks.
Yeah they will not fit, the centerbore is not the same size as the xterra's. I was about to get a used set for my 2001 and last minute i found out that the centerbore size is too small. Wish all the nissan trucks and suv's used the same dang centerbore, what jerks
I have a 1/2" rabbet bit and have successfully "machined" caddy wheels and titans to fit on a frontier. The back spacing on titan 18s make me wonder about turning though. They are pretty deep.
I have one wheel I am going to throw on to test, picked it up for $35. the other 3 will probably cost a lot more.
after further review, I wouldn't feel comfortable removing that much metal to clear the hubs. you have to bore the wheel out so far the center cap would be gone. on 2wd, you only need 1/2" deep to clear the centering hub. GM aluminum wheels like silverado or Eskies can fit, just mod the center cap or don't run it.
75.3K members
