also use the search tool to do some searching befor posting a new ?..... more than likley there is someone that has had a similar problem, if you cant find anything them ask away... we will be glad to answer then.......
that was the only post form the guy so good luck on getting a answer... a few others have had to replace the Blower motor resistor... if it works on hi but not on the lower setting then that is your problem... post up in the new member introduction and stick around a while...
definately the blower resistor, a 20 dollar part. i just fixed this on my 00. it is a common problem. just unscrew the glovebox's 6 screws and it will just drop down. the blower motor/resistor are under there.
I have a similar though slightly different problem. At first the blower would only kick in occasionally usually after hitting a bump or something and now it's not working at all. I tried tapping the blower motor housing and the blower kicked on but the air conditioning would only work on setting 1. Could this also be a blower motor/resistor combination? Any help would be great guys.
Up here in Canada the resistor is $100 and the motor without fan is $85. Thanks.
Yours is a different problem. Could be a loose connection, or a problem with the motor itself. EIther the brushes in the motor are worn out, or they're stuck. You can take the cover off the motor, check the brushes, and if there's still brush material there, lube them up.
Also check the electrical connections at the motor, as it could be a loose connection there.
Hi guys-
Old blower motor resistor was only running my blower on the high setting, so I replaced the resistor, then the fuse and it worked great for about 5 days. Now it only works on high again. Almost seems like the resistor part went after only a few days? Any ideas? Thanks.
i have the same problem with my 06 xterra, but for mine all the stage are not working, not 1-4, no fan only hot air, i have try replacing fan motor, resistor, and relay too but nothing seen to be working, running out of option, please help if anyone know anything, trying to get it fix before winter hit
max
75.2K members
