My buddy has a 99' Jeep Wrangler, but after more than a decade living in salt ridden new england and 130,000 miles of hard driving and a careless PO its in need of some restoring.
He picked it up a year ago and really only lifted it with 3/4" spacers and gave it some nice tires. After I purchased the X it got him a little more into the bug.
We prepped and primed the tub for a full bed liner job along with a new bumper he pulled off our buddies sadly traded in rubicon.
Yeah I bet the MEK is slowly killing my kidneys after that one
Tim taping off for bed liner
aint that purdy!
Under the sliders
fender paining
Beast
Well we knew it was coming, the infamous Dana Turdy5 started screaming. A mechanic had naively overtorqued the pinion nut to set the yoke farther in due to it being gouged. A few months later the overstressed bearings were destoyed. It was time to replace all the parts that are prone to breakage.
He selected a truetrac geared limited slip to eliminate the weak carrier and spider gears that all to often in the jeep world go through the diff cover unexpectedly. 4.56 Superior gearing was chosen to give the anemic 2.5 an easier time getting up in the revs and Superior 4130 discovery series axle shafts were chosen to replace the weak stockers.
That worked really well.
The bearing was definitely shot, and upon further inspection of the diff we found small metal shards of what was left of the outer and inner bearing components and an abnormally large amount of metal dust from all the gears.
We ordered up all the parts needed, but were missing a couple so we headed off to the dealership. Talking to the parts guy we saw another guy working on a diff. Started talking and thinking it was more like a D44 thought we had to press the bearings onto the shaft. He was nice enough to correct us with out insult that they were to be compressed to the housing. We asked if we bring it in can he press them for us. "the housing?" looking at us blankly. "Yeah" time replied. "Uh, the housing? you want to bring it in? Its the heavy thing." "yeah we removed it.", "Uh, the housing? the whole thing, right?", "Yep its sitting on the floor on jack stands right now." He just looked at us blankly, turned and walked away.
guess that attitude goes with everyone else telling us we can't set a diff without previous knowledge. hahaha
So we ripped her apart and got the trutrac ready and willing.
Long story short after you have perfectly mastered the bearing, shimming and backlashing parts, there's still one little piece left of the puzzle. That thing called a crush spacer.....
Undoubtably the most evil part of this whole experience. If you mess up well, your SOL. Start all over again. Tim first found out the hard way as did I about over torquing the damn thing. It went from 6 in/lbs on the pinion to 30! how the hell can you do that.
Crush sleeve #2: I overtorqued it. Lets try again.
Neadless to say there was much drinking after that one.
What? wine out of the bottle? What can I say, Im a classy SOB.
Tim taking his frustration out on the bottles cap.
Well we ordered the new crush sleve and went to work for the third time.
Spaced, torqued and tested.
Nate tighnting up the pinion nut.
Money Shot.
The final test. WE HAVE PINION AT 13 IN/LBS! (spec is 12-14)
There was much rejoicing.
She's done. Well.....almost
Now its getting prepped and painted.
the new differential cover
Some of my paining handy work.
We removed everything from the rear end. Oh did I mention everything under that wheel well is getting replaced!
Well now that the rear is almost finished guess theres only one thing left to do....
Yeah the parts for the front came in. That project starts Friday!
:wink-big:
aint that purdy!
Under the sliders
fender paining
Beast
Money Shot.
:wink-big:
